Introduction: Wooden Espresso Knock Box
Turn a utensil container into knock box. Way better than banging your portafilter in the sink, and cheaper than a retail one.
This method can be used with any container with a wall thickness of .5" to .75"
I used my wife's "Giadia Bamboo Utensil Holder" This has a wall thickness of .75"
A big section of pvc pipe works too.
I picked up all the supplies at my local Lowes.
Supplies needed:
-container
-length of .5 inch copper pipe
-Two .5" cooper pipe caps
-clear tubing (reinforced)
-rubber grommets (i found an assortment pack that had two .5 inch grommets)
-index card (for transferring cut line)
Equipment needed:
-Drill
-1" bit (I used a spade or "paddle" bit) This is based on the outside diameter of the grommets' inner ring...
-clamp (quick clamp or pipe clamp)
-hacksaw (or Dremel)
-coping saw
-crosscut saw (chop saw if you have it)
-safety stuff, glasses gloves and a mouthgaurd
-rounded file
-fine sand paper
Step 1: Measure and Cut
For my set up, I needed the knock box to fit in my espresso machine. Specifically, it had to fit in between the portafilter and the drip tray. This saves counter space and can also be used to catch drips. If you have a Gaggia Baby Class, then make your container 4" tall.
Step 2: Drill Holes
Practice making the holes on a scrap piece. Clamp the scrap to something to keep it from moving. I ended up having to slow the drill speed considerably at the end to avoid chipping out the back and having the wood ripped out of my hand. (hence mouthgard) A little chipping is okay and even a little burning is okay because the grommets will cover a bit of the hole edge. The hole will need to be slightly expanded to fit the grommet.
Measure 1 3/8 inch down from the top on both sides. If you plan on this fitting between the portafilter and the drip tray like mine, start doing some measuring for appropriate height so the bar will clear the spouts.
If you are feeling reckless, hold onto it with your hand. If not, clamp it down and drill baby drill.
Step 3: Cut Out "mouth"
Draw an arc for the mouth of the knock box on the cardstock.
4.25 inches across, 1.75 inches down.
Cut it out and trace it onto the wood.
I coped it out, but you could use a jigsaw.
It will be rough, but files and sandpaper make it look pro.
Step 4: File and Sand
Use a rounded file to expand the hole a bit. Keep checking the size by shoving the grommet in to check.
Make the "mouth" smooth.
Step 5: Insert Grommets
Pop in the grommets. I ended up using some pliers to pull them in.
Step 6:
Slide the pipe through to make sure it fits
Cut the pipe leaving enough for the end caps.
Debur the cut ends with files.
Step 7:
Cut the clear tubing to fit between the two grommets. Slide the pipe through, ad pop on the endcaps.
Mine pressure fit fine so no glue/soldder needed. You could slightly squeeze the copper pipe ends to make the end caps fit tightly.
After months of banging, no lose caps yet.
7 Comments
6 years ago
great thing. Beautiful made.
7 years ago
It's good to see that it's easier than we think to built a knock box at home. The wooden block is way better than using the PVC as I guess, it's not going to bear much knocks of portafilter. However, here is a list of few knock box that comes cheaper, http://www.friedcoffee.com/top-7-knock-box-for-espresso-grounds/
7 years ago on Introduction
FYI: The tried and tested method used by carpenters for preventing chipping out when drilling is to place a sacrificial piece of wood on the back end. This works by keeping the wood being drilled through from being 'pushed' out into space by the drill bit. Since the knock box here is curved (although this project could easily be done with a square or rectangle), simply take some of the extra material cut from the top in Step 1 and cut it into sections just wide enough so they can be clamped to the inside of the knock box. The radius isn't exactly right of course, but if the scrap isn't too wide and is clamped tight enough, most of the chipping out should still be avoided.
To make cutting the mouth out in Step 3 easier, another carpentry trick is to first saw down several cuts roughly perpendicular to the curve, dividing what will become scrap into several sections. As the curve is then cut, each section falls away, making it much easier to position the coping saw and less likely to leave the line of the curve.
Roger that. Although when the wood is curved, the sacrificial wood trick doesn't work regardless of adding extra wood to fit the radius. Keeping in mind clamping too hard would crack open the joints.
If this was a project I wanted to be extra pretty, I would have cut into the wood an 1/8 inch with an exacto knife following the size of the hole I was drilling. That works everytime.
Thanks for the pointers!
8 years ago on Step 7
A better method for the knock pipe would be to cut two indentions on the top of the box. That way you can more easily remove the pipe when cleaning. Otherwise, nice project!
10 years ago on Introduction
Nice project, and great guide. What was the mouthguard for?! Is that for when your wife finds you cutting up her utensil pot?
That, and trying to make smooth hole with the drill. On my first attempt with a practice piece, the drill grabbed the wood and spun the whole piece around like a wheel of death.
