Introduction: Wooden Machete
I am makeing a Woden sword widling
All you need is a pencil a knife and a scrap piece of wood
Step 1: Make a Line Where the Handle Is Going to Be
Step 2: Make a Slit Where You Marked
Now you make a slit where you marked
Step 3: Widdle the First Layer Off
Now widdle the first layer off
Step 4: Widdle Where the Side Where There Will Be No Blade and Make That Into a Flat Side
Where all the side weather is going to be no blade and then we’re all that side into a flat edge
Step 5: Widdle the Other Side
Do the same thing you did on step 3but on the opposite side
Step 6: Makeing the Tip
Make a slit where the tip is going to be
Step 7: Start Chipping
you need to remove the top so chipping away on the top
Step 8: Remove the Top
Once you have chipped enough The top should be gone if not try to remove the rest of it
Step 9: Make the Blade Thiner
At this point it’ll be hard to make the blade with the body being so thick so make the body thiner
Step 10: Make the Blade
Now that the body is thinner it’ll be easier to make the blade so take your knife in widdle Out a blade
Step 11: Make It Sharper
Now little best you can to make it as short as possible
