Introduction: Wooden Neighborhood Map
This wooden map of San Francisco is all made out of one piece of plywood and shows all of the neighborhoods of the city thanks to different types of wood stain.
Step 1: Supplies
What was used in the making of this map
- 1/4" plywood
- laser cutter (or coping saw)
- 5 different types of wood stain
- Elmer's Carpenter's Wood Glue
- 1/4" plywood
Step 2: Cut!
OK, so I have access to a laser cutter. It makes this job as easy as pushing a file to the laser cutter and watching it go for about 10 minutes. It's awesome. I wished I owned it, but will make do with access to it.
You can also do this with a coping saw and a drill and a LOT of time. If you do, you are a fantastically wonderful human being and I admire your patience.
Step 3: Stain Map
Before applying stain, print out the neighborhood map on paper and use a pencil to plan out where all of the different types of stain are going to go so that you don't have two pieces of the same stain touching each other.
Step 4: Stain All the Pieces
With your number chart handy, pull out all of the pieces and carefully stain all of them according to your chart.
Step 5: Glue Back In
With a couple coats of stain on all the pieces, it's time to glue everything to a backing pieces of plywood so that it stays put. Here, I coated the entire backing piece with lots and lots of Elmer's Carpenter's Wood Glue.
Then put all of the pieces back in and cover it with another piece of plywood. Clamp the corners and put a heavy weight in the middle of it all. Let it dry for a while before taking everything off.
Step 6: Hang and Enjoy
That's it! It's done! Now it's just time to ind some place to put it and enjoy it.
