Introduction: Wooden Practice Joints
I was getting tired of having to repeat myself and continually going over instructions sooooooo time for an instructable.
Step 1: Things/tools You Will Need
600 mm of dressed 65x19 Pine
Marking gauge
300 mm steel rule
45/90 set square
Chisel
Wood rasp
Tennon saw
Bench block
Spur point drill
Step 2: Mitered Corner Halving Joint
Steps:
mark a 45 degree angle using the set square
where the 45 degree intersects with the edge mark 90 degrees
using the marking guage mark half way, 9.5mm
using a tennon saw cut down to the line on the 90 degree line cut the remaining end of at 45 degrees
ALWAYS try to leave pencil lines on as cutting lines of will cause loose joints
measure 120 mm down from the other end using set square and cut off
on the 120mm end mark and cut at 45 degrees
measure half way down and remove the other half of the joint
use a wood rasp to ensure the joint is flat and level
TIP when cutting the 45 degree angle make sure you cut the correct side or you will end up with a straight joint
Step 3: Dovetail Joint
Steps:
cut another piece from the end at 120mm
measure down the thickness of the timber and using a square mark a line on all sides
using the marking guage measure, set to 9.5, mark the end 45mm end and sides of the timber
cut half of the 45mm end off
turn the timber over and using the 90-degree line 45 mm down mark in 12mm from each end
using a ruler draw the taper
using tenon saw cut the taper
measure down 45mm from the last joint and draw a 90 degree line across the face of the timber
