Introduction: Wooden Sail Boat.
I made this sail boat out of off cuts and scrap wood i found in the shed.
Step 1: Glued Up
I first started by looking around the shed to find any bits of wood i can. I then put them all together and decide on a shape i wanted. After that i then glued it all together .
Step 2: Shaping
After the glue was dry, i then carved the bottom of the boat using my grinder and a sanding disc.
Step 3: Details
I started by drilling loads of holes to put cocktail stick in and use as the hand rail. I also carved out the stairwell and made 3 doors out of lolly pop sticks. I also used lolly pop sticks to make it look like there's a decking.
Step 4: Sails
I drilled out for the sail post and put them in. I nailed the vertical post in and made the sails out of old curtains. I added a bit of wire in the sides to help it keep its shape.
Step 5: More Details.
I 3D printed an Anker and some chest and painted then. I also made the wheel out of a small bit of an off cut and made it connect with a cocktail stick, giving it the ability to spin.
