Introduction: Wooden Scrap Bird
This is a quick project for two lessons in the woodwork shop.
Students should make use of scrap pine (which we have a lot of).
This project is to practice the following skills:
1. Marking a curved line and cutting using either scroll saw or coping saw.
2. Matching a driver bit to the thickness of a dowell and drilling holes.
3. Bonding with PVA glue.
Step 1: Drawing a Bird With Two Curves.
Starting from one corner, I drew an S shaped curve to the diagonally opposite corner. I then drew a second below it. Between these two curves is the body of the bird. Put an eye where you think the eye should be.
Step 2: Cut the Bird Body With Scroll Saw and or Coping Saw.
Slowly and carefully, cut the two lines using either the scroll saw or coping saw.
Step 3: Use the Left Over Pieces to Make Two Wings.
I stacked them on top of each other to figure out a wing shape that used as much of the scrap as possible.
These we also cut on the scroll saw.
Step 4: Assembly
These are the four pieces that make up the bird:
- Body
- Wings
- Dowell.
Step 5: Drilling Holes in the Wings and Body.
Because the drill bit is almost as thick as the wood, there was a risk of splitting the wood. I was extra careful to clamp these pieces in the vice or G-clamp so they could be drilled accurately, without damaging the wood, or hurting myself.
Step 6: Sanding --> Glueing.
You can now sand and finish the parts of your bird. I wanted to make this friendly to young hands (Ages 1+) by taking off any sharp edges.
I used a little PVA glue to secure the dowell inside the wings.
