Introduction: Wooden Test Tube Wall Planter
About: Handmade crafts and products that I make using recycled or waste, cheap and easy to available materials. Also custom products are made using a mix of materials.
Indoor wall planting are very rare and organized way to provide decoration, that's why I built this Wooden Test Tube Wall Planter or you can say a plant propagation system that can carry a single tube for holding the plants.
Many studies say that Indoor planting is a great way to decorate your home at the time it improves the air quality of your room. But a single plant won't make a difference, the bigger the leaf the better. Because, a person spends most of his time inside a room or office or like that. So, it is very much important to breath a quality air as much possible. And an indoor planting may help you achieve a circulated pure air.
Also, wall planting can decorate your room in a different way as well it can move your space from the desk to the wall. Most of the plantings are done on tabletops or in plant pots, but wall pots are not generally seen everywhere.
So, I've made a simple way to get some indoor plants and organize them in a very decorating way to improve you home. So, let's see the making now.
Step 1: Tools and Materials
Below are few Tools & Materials that will be needed for making the product,
TOOLS
  • Hacksaw
  • Drill Machine
  • Drill Bit (16mm hole cutting bit)
  • Sandpaper
  • Ruler
  • Cutter
  • Curving Tools
  • Hammer
  • Nails
MATERIALS
  • Test Tubes
  • Wooden Beads (4mm thick)
  • Wood Pieces (15mm thick)
  • Wood Glue
  • Double Sided Tape
  • Varnish & Brush
Step 2: Cut the Wooden Bars
I used some 4mm gamari wood beads here for making the back plate. Then I marked about 7 inch each and cut several pieces of them. Because a single planter won't look as good as several planters together.
Then I sanded and made them smooth.
Step 3: Mark & Drill Tube Holes
Next I used 15mm thick wood pieces for making the Tube holders. Then I marked the center and drilled holes with 16mm drill bits. Because we are going to use 15mm Test Tubes here.
Step 4: Cut and Sand Tube Holders
Next, cut the wood pieces and made them smooth by sanding every edges and the hole too.
Step 5: Final Pieces to Join
Now, here I have made a few planter pieces and they are ready to join together.
Step 6: Fix Tube Holder to the Back
In this step, I used some regular wood glue to join both the pieces together. Also I hammered a couple of nails in the back to give some extra protection, so that it may never get loose in future.
Step 7: After Dried
So, after the wood glue dried up, the planters looks something like these.
Step 8: Apply Coating Agent
Next, I used some Varnish as a coating agent and applied all over the areas. It suddenly enhances the look, gives a shiny texture and also protects the wood in long run.
Step 9: Final Product
Here is our final finished product of wooden wall planter for holding test tubes. This is a preview of our planters before mounting to the wall.
Step 10: Attach to Wall
Next, I used some double sided tape and added to the back plate of our planters.
Then I attached them to the wall in a random manners like, in unequal heights and in equal distances.
Thus it looks really beautiful and attractive to any visitor that notices it.
Step 11: Test Tube Wall Planter
So, this wooden test tube wall planter is a very pretty and easy to makeHome Decor item that can suddenly enhances the look of your wall.
It is very much suitable for bedrooms, offices, drawing rooms, restaurants, waiting rooms or any public places.
Comment below, where else you use this planters.
Also, comment any doubt or suggestion, I would love to hear those.
__
Lastly, Thank you for reading this instructable. If you've liked the documentation please Follow us.
Also, SUBSCRIBE to our YouTube channel "technocraft STUDIO" for more amazing Crafts and DIY Products like this.
__
GET IN TOUCH
Facebook : https://www.facebook.com/technocraftStudioPage/
Instagram : https://www.instagram.com/technocraftstudio
YouTube : https://www.youtube.com/c/technocraftStudio
Website : https://debojitpaul.in/technocraftstudio/
E-mail : technocraft43@gmail.com
