Introduction: Woodturning With a Drill Press
- Using very few materials and common hand tools you can turn your drill press into a small lathe for wood and plastic.
- Three examples of increasing difficulty are described here in some detail, a bottle stopper, a tool handle and a cylindrical piece. These examples serve to illustrate different methods of work , useful to anybody willing to try this modification.. .
- I also show several other things I made in the past that may give you ideas for your own projects.
Step 1: The Set Up
The idea of turning a drill press into a small lathe is not new. The setups that you may find in the internet include
- The work of the instructables contributor Tool Using Animal (https://www.instructables.com/id/Drill-Press-Lathe/)
- A few youtube videos.
- A commercial product under the name of Vertilathe
The tool rest
This is a vertical block of wood 12 cm x 5cm x 1.5cm firmly screwed and glued on the basis. It serves to slide the tool up and down along the edge of the working piece. Furthermore it protects your hand from getting to close to the turning piece. The length depends upon the available space you have in the drill press. In retrospect I should have made this a few centimeters longer.
The live centre
This allows the working piece to rotate around a stable axis. It consists of a short axis with a conical shape usually mounted on a ball-bearing. I made mine in the simplest possible way and it proved enough. It is made out of a screw free to rotate in its hole, supported by double nuts and washers.
Step 2: Methods to Hold a Piece
There are several ways to hold the piece on the drill. In the examples to follow I'll describe the use of three of them.
- A home made spur centre. This is the more stable of all. The central screw keeps the work in line and the three pins keep the piece from turning loose. It is used by drilling a hole for the central axis and hammering the pins in the wood.
- A screw shaped as a double edge. This works best with medium and hard woods. It is preferable when you need to work with pieces of small diameter.
- A common screw with a bolt. This serves when you do not want to use the live centre.
- Some people use a Forster bit (the last in the photo) but I was not successful with it.
Step 3: Tools
- Since we are dealing here with small pieces, a set of wood curving tools is more than enough. From a set of six I only use the basic knife and the larger gouge. I also made another tool from an old knife for marking and fine details. The handle was made with this lathe.
- I think that two more tools would also be useful, a flat chisel and a chisel with a round edge for the concave parts..
Step 4: SAFETY
- A drill press can be dangerous as it is for someone without experience. It may become even more dangerous when you are using a chisel with it!
- Always wear gloves and safety glasses.
- Keep your hands behind the tool rest.
- Do not press the tool too much on the piece.
- Stop when you hear unusual sounds when the piece turns. Something may be loose and become dangerous. And finally:
Your hands and eyes are worth much more than a bottle stopper!
Step 5: First Demonstration: a Simple Bottle Stopper
This is a simple project which will forgive a lot of mistakes.
- Cut a wood piece of your preference about 6-8 cm. The cuts should be as parallel as possible.
- Drill a central hole for the spur centre on one side and another one on the live centre on the other side..
- Hammer in the spur centre.
- Mount everything on the drill and align by small displacements of the table.
- Turn for a short time to check if it is aligned.
- If it is right tighten the screws of the base on the table.
- Start wood turning. First make a cylinder and mark the size of the object.
- Continue with the conical surface.
- Work slowly and stop frequently to check how it goes.
Step 6: Finishing
- This stopper is meant to work with a rubber o-ring. So, make two marks for different diameters.
- While the piece is still on the drill , sand it. I use at least three numbers of sand papers, 80,100,120.
- Remove the piece from the drill and mount it on a vice. Use a saw to cut off the upper and lower parts of the piece.
- Mount the o-ring and test it on a bottle.
Step 7: Second Demonstration : a Tool Handle
- The working piece is a part of an olive branch dry seasoned for more than a year. We are going to make a tool handle out of it, but this time we need good alignment with the axis of the tool.
- The piece will be supported from a shaped rod ending in two pins (the second piece holder in step 2).
- First you support the branch from a vice and drill a 6mm hole on the one side deep a few centimetres and a more shallow hole to the other side for the live centre.
- Then you hammer in the supporting rod to the upper side and mount it on the drill.
- The turning steps are shown in the photos.
Step 8: Mounting the Tool and Finishing
- I used the hole on the piece as a guide to form the hole for the tool to put in.
- This was made by mounting the handle again on the vice (protected by two pieces of plywood) and drilling a deep 3mm hole and a more shallow 4.5 mm.
- The tool was forced in by hammering with a wooden mallet.
- Thin varnish was applied to the handle.
Step 9: Third Demonstration: a Cylinder
- We are going to make a rather large diameter cylinder. The main problem here is the alignment of the internal to the external surface.
- Making a cylinder first and then trying to drill a hole is a process more apt to failure. In this example we are going to work inside-> out by first drilling the hole and then trying to align the external diameter to it by mounting it on a suitable support.
- The hole was done with a 35mm Forster bit and the hight was 55mm. The wood was very soft and this caused some problems.
Step 10: Building a Support
- The support is needed to align the hole to the drill axis. I used an 8mm threaded rod. I also made two 35mm wooden disks to fit the inside and two larger 40mm disks for the outside.
- Since a tight contact to the hole was needed, I used pieces of tape on the inner disks.
Step 11: Turning the Cylinder
- Then the piece is mounted on the chuck and turned. The support was strong enough and turning was easy.
- However I am not satisfied with the final result. There was a misalignment of 0.5mm between the internal and external surfaces that I think I can improve the next time by doing the following:
- The piece should be completely immobilized on the drill table for making the hole. I did not do this and the result is a shift in the drilling since the wood was too soft.
- A harder wood should be used.
- I should also use double nuts to hold the supporting disks on the axis.
- A good idea is to add a piece of wood to connect the axis to the live centre. This would improve alignment.
- Overall the method works, however it needs more careful praparation.
Step 12: More Bottle Stoppers
- This is the first applicaton i worked a lot with. I made a couple of douzens and gave them as small gifts.
- I tend to prefer the o-ring version. The cork needs replacement after extended use.
Step 13: More Tool Handles
- I have made several handles for small tools, the most of them for blades.
- The first three shown in the photo have a place in a small portable toolbox in the house. They are a 1.5mm drill, a saw and an awl. The have saved a lot of situations where delicate work is needed..
Step 14: Wooden Wedges
- Wooden wedges can be made by mounting a cylindrical dowel directly on the drill chuck. The live centre will be needed only if the piece is too long.
- These are usefull for repairs. Two years ago I restored a badly damaged classical guitar. I used a wooden wedge across and special glue for instruments to repair the broken key part. The complete restoration lasted 2-3 months and it is a story of its own. Some information is in the photos below.
Step 15: A Wooden Mallet
- The same spur centre was used for a simple wood mallet. i also have made a few of these for gifts.
Step 16: Pencil Holders
- I like using these pencil holders for small pencil bits.
- A similar project is to make wooden pens using commercial pen sets. I think that this is doable with this drill press setup.
Step 17: Spinning Tops
- Spinning tops is another project worth trying. I have made several as small gifts.
Step 18: A Final Word
- Of course you cannot turn salad bowls or furniture pieces with this small tool.
- One thing to remember is that the drill press is designed to operate vertically and by using the chisel on the work piece you apply horizontal forces on the axis that will tend to destabilize the system. So do not overdo it or you may see the chuck flying around the room (it happened to me).
- Currently, after exploring its possibilities, I use this modification only as a side tool to make parts for other projects (like wooden wedges or cylinders) or to fit sizes in wooden or PVC pieces.
3rd Epilog Challenge
49 Comments
8 years ago on Introduction
very well done, I like the projects you created with this
Thanks. I do not fool myself that I have a lathe, but occasionally this helps me in making small parts.
Excellent instructable and super useful. I'll be using this for my next project and pointing users here for a more thorough explanation of this part of the process.
Thanks. Be always aware that this is not a regular lathe, it is only for small parts since the axis of the drill is not designed for vertical pressure. So one must shape the piece as much as possible before putting it on the drill press for lathe work. Alignment is also critical and should be done carefully.
9 years ago on Introduction
Thanks! This is only for small parts. Be careful to align the piece as good as possible and don't push it too much..
9 years ago
This is awesome. ive aways wanted a lathe but I do have a drill press so finally my quest is over.
If you want to do this regularly change out the regular bearings and replace with thrust bearings.
This is a sound advice, thanks for pointing out this possibility. I understand your concern about the side load . However I have been using this setup for at least 3 years now and I control the condition of the drill - specially the axis - often enough, no problem until now. The meaning of this instructable was to explore the potential of the tool for small lathe work not to turn it into a lathe. A real lathe is designed differently. It is true that at the beginning I was carried away and made bottle corks, handles etc but now I only do limited lathe work to help me in other projects e.g reducing diameters of rods, small wooden or PVC disks etc. Many people - including myself - use sand drums on the drill press, a process which also introduces side loads on the axis.
11 years ago on Introduction
Wood lathes are easy enough to make. I've made a couple.
http://i.imgur.com/M3x9o.jpg
http://i.imgur.com/V5mzn.jpg
OK, maybe I just made one, then remade it when I re-purposed the headstock of the original after I figured out what it really was.
http://i.imgur.com/nF8yR.jpg <-- the old headstock ended up as the grinder on the top left, the one with the bulldog style drill bit sharpener on it.
Another picture of my homemade lathe:
http://i.imgur.com/3Wezj.jpg
12 years ago on Step 5
Did I mess something, or there a step missing on how to align the dead center with the live center in the chuck ? Most drill press tables will move about the pillar when adjusting table height, so by what means are you centering the dead center accurately below the live center.
The step describing "dead centers" seems to be confusing. Looks like a terminology issue. Check any lathe text book. The center on the powered or drive end is called the "live center". The point on the non drive end is called the "dead center" There are also "live dead centers" which are not driven or powered, but have an internal bearing so that the friction is handled by internal bearings while the cone or spur center stays fixed in the work piece. This prevents frictional damage to the end of the work piece and the dead center.
As far as I can discern from the instructions, the reader is left to figure out how to deal with live and dead centers and aligning the dead center with the live center. In light of this, by what means are you applying pressure to the dead center to force it into the work piece while keeping it aligned with the live center ? On a conventional lathe these issues all look after themselves by the design of the machine.
Reply 11 years ago on Introduction
The two ends of a lathe are called the headstock, and the tailstock. You put a live, or a dead center into the tailstock. Good lathes allow you to offset the tailstock for taper turning. Then it is left to the operator to realign the tailstock for cylindrical turnings. It is how I made my lathe. How close your alignment is isn't always as critical hand turning as one might think it would be, as you can compensate for it somewhat with your chisel traverse.
Live dead centers are commonly referred to as simply live centers, so they aren't confused with plain dead centers.
They don't call drill presses presses for nothing. You can use the racks and pinions in them to develop plenty of force to keep a piece mounted.
Reply 12 years ago on Introduction
Dear dieseldude,
The support of the piece is a "live center" , because it rotates freely due to the double bolts and washers. I cannot use a dead center with this setup.
Alignment is indeed addressed in step 5 and it is possible with this setup. Otherwise there would be no results, right? First the base is mounted and the screws are kept loose. Then the piece is mounted on the chuck firmly. The live center is introduced into the lower hole and aligned by checking against the tool rest. The system is rotated for a while and if the position is qood then the base is fixed.
ooooooooooooo i wish i had a drill press
11 years ago on Step 4
hey thanks for the tip there it seems like a fun way to use the drill press and save some space, but...
one minor correction, gloves rings and bracelets will catch on a lathe and should never be worn when the tool is on! heres a good site
http://www.woodturner.org/resources/safety.htm
ctrl+c ctrl+v
Reply 11 years ago on Step 4
I agree with you. I was a little carried away in trying to emphasize safety. I do not use gloves either, even when sanding the piece on the drill press.
12 years ago on Step 17
you tie the top kinda weird
I've been lathing for sometime now but I can't get my head around the fact that this lathe turns vertical. I keep holding my lathing tools the same way I normally do... I think I'll just stick to a normal lathe.
Dear Cubie2,
If you have a normal lathe, stick to it!
However you get used to the vertical easily, there is no problem. The major problem in the drill press is aligning the piece as good as possible and securing it safely.
Of course this drill press application is very limited and as I have said to other posts, I only use it now for small jobs and modifications. It is no substitute of a real lathe, it is only an extension of an additional possibility for a tool used as drill 98% of the time.
great idea, thx tholopotami
I am glad you liked it!
However if you want to do it yourself , consider all comments about safety.
