Introduction: Woodwork With Electricity Use Electricity to Burn Sporadic Designs in Wood - Using Electricity to Make Artist Designs in Wood
Using a transformer from an old 1000w lighting fixture I am able to arc a current threw wood and create random designs in it. I do not recommend you try this without electrical experience and i am not responsible for you hurting yourself.
- Water
- conductive powder to mix with the water
- two screws
- 1000W lighting transformer for an exterior lighting fixture
- enough wire to run 3 or 4 feet away from your transformer to wooden plank
- a piece of wood a few feet long
Step 1:
OK so this is what I did again I do not recommend you try this without electrical experience and i am not responsible for you hurting yourself.
- I ran 2 screws into my board a good distance apart in this video you're looking at almost 2 feet apart
- I hooked the ground (green wire) or wire connected to something at least 8feet in the ground to one screw and I Hooked the hot wire coming off of the 1000w transformer (wire going from the transformer to the bulb that carries voltage) to the other screw
- get some water and mix some conductive powder into it like graphite powder or something electricity can travel through... so I used graphite powder but there are other things you can use. If you have a red solo cup full of water, I'd start with a measuring cups worth of your powder,
- with the power off I do not energize the transformer yet, I'll use a towel and slosh some of my water mixture onto the board and get it good and wet in between both screws. like all the way from one screw to another.
- Step back and turn the power on I do not touch the board or anything around it while the power is on.
- If I am not seeing the electricity start burning its way from on screw to another, I turn the power off and make my mixture with water a little thicker and then reapply to the board step back and try agian
