Mens Vest
Intro: Mens Vest
STEP 1: Materials
4 Yards 45" fabric pre-washed, dried, and ironed.
4 Yards 45" wool fabric pre-washed, dried, and ironed.
Matching thread.
A vest with all the seams, threads, and pockets removed and pressed.
18" Metal zipper
STEP 2: Tools and Supplies
Ironing board.
Sewing machine.
Zipper-foot attachment helps to sew a close seam but it is optional.
Scissors.
Seam ripper.
Thread.
18" Metal zipper.
Straight edge optional.
Tape measure. optional
Sewing pins.
Marker.
Chalk optional.
Label optional
STEP 3: Pattern Layout
Before cutting: Check how large the seam allowance is on the existing vest as you may need to add extra for a seam allowance before cutting out the vest or the fit will be too small.
Spread the fabric out on a table.
Lay the back vest piece on the fold of the fabric and pin it into place. Cut one.
Lay the front vest pattern piece on the selvage edge of the fabric and pin it into place. Cut 2 from fabric.
Lay the pocket piece on the straight edge of the fabric and pin it into place. Cut 4 pocket pieces.
STEP 4: Pockets
With right sides together sew the top of the pocket together following the lines.
Turn.
Trim loose threads.
Press.
Place the pockets to the front of the vest and pin into place.
Edge stitch the pockets to the vest front leaving the sides open.
Top stitch for a finished look.
STEP 5: Wool Lining Layout
Spread the wool fabric out on a table.
Lay the back vest piece on the fold of the wool fabric and pin it into place. Cut one. This will become the lining for the vest.
Lay the front vest pattern piece on the selvage edge of the fabric and pin it into place. Cut 2 from wool fabric. This will become the lining for the vest.
STEP 6: Sew Vest Front to Vest Back
Sew vest front to vest back with right sides together.
Trim loose threads.
Press seams open.
Set aside while you sew the vest lining in the next step.
STEP 7: Sew Vest (Lining) Front to Back at Shoulders
Sew the vest lining front to the vest lining back at the shoulder seams with right sides together.
Trim loose threads.
Press seams open.
STEP 8: Pin the The Vest to the Lining
Pin the lining to the vest matching the seams at the shoulders and sides wrong sides together.
Sew around the front opening and neck area edges 5/8".
Sew around the sleeves 5/8" leaving the sides open.
Clip the curved area.
Turn right side out.
Press.
STEP 9: Sew Lining Side Seams
Pin in and sew the lining side seams.
STEP 10: Sew the Vest Side Seams
Next pin in and sew the vest side seams.
STEP 11: Zipper
Next separate the zipper so you have two pieces.
Pin the zipper pieces to the right side and left side of the vest as shown.
Using a zipper-foot stitch as close to the edge as possible.
You will need to move the zipper pull towards the top of the vest so you can continue sewing down the vest front.
STEP 12: Top Stitch for the Finished Look
I think top stitching around all the edges adds style to a garment.
This step is optional.
I top stitched around the sleeves, hem, neck, front band, and pockets.
STEP 13: Label
Sign the label.
Center the label on the neckline of the vest on the inside of the vest and pin into place.
Iron according to the directions.
STEP 14: Sunshiine's Final Thoughts
Thank you for stopping by and please do stop in again soon.
Sunshiine
12 Comments
annxtte 12 years ago
sunshiine 12 years ago
susanrm 12 years ago
Sunshiine
Penolopy Bulnick 12 years ago
Sunshiine
SIRJAMES09 12 years ago
when it comes to serious sewing, I'd screw up a one car funeral. :(
I do good to sew a straight line let alone a curve...
Sunsniine, you're have to be the most wonderful Lady I know! That vest, the Instructable, the pics,....all of it, fantastic!!!!!!!
How much you want to make me one?? $50? $60? more? that vest + your time & effort is more than worth it!!
TY for sharing Ma'am.
Sunshiine
pecospearl 12 years ago
sunshiine
canucksgirl 12 years ago
Super Job!!!
sunshiine
