Introduction: Hosting Your Own Website in 6 Easy Steps
We all are familiar with WordPress. It is a free and open source online content management feature, this allows us to host our websites with ease. WordPress is used by 63.5% of all the websites whose content management system we know. This is 43.2% of all websites. It combines simplicity for users and publishers with under-the-hood complexity for developers.
Only a handful of things are required to get started
  1. BrainyPi or Raspberry pi
  2. Wifi/ ethernet
  3. Micro SD card loaded with debian
  4. keyboard
  5. mouse
  6. monitor
  7. A domain name
Step 1: Start by Installing Docker
1.1 Before installing docker and its dependencies we need to do a few steps
sudo apt-get install \
   ca-certificates \
   curl \
   gnupg \
   lsb-release
1.2 Add docker's official GPG keys
sudo mkdir -p /etc/apt/keyrings
curl -fsSL https://download.docker.com/linux/ubuntu/gpg | sudo gpg --dearmor -o /etc/apt/keyrings/docker.gpg
1.3 Use the following command to set up the repository
echo \
  "deb [arch=$(dpkg --print-architecture) signed-by=/etc/apt/keyrings/docker.gpg] https://download.docker.com/linux/ubuntu \
  $(lsb_release -cs) stable" | sudo tee /etc/apt/sources.list.d/docker.list > /dev/null
1.4 Finally, install Docker Engine
sudo apt-get update && sudo apt-get install docker-ce docker-ce-cli containerd.io docker-compose-plugin
1.5 Lastly, run this to test the installation
sudo docker run hello-world
Step 2: Creating Configuration Files
2.1 Start by creating a directory
mkdir ~/wordpress
2.2 Create nginx.conf file
nano ~/wordpress/nginx-conf/nginx.conf
2.3 Now paste the following in the file and make sure to change "your_domain" and "www.your_domain" to your domain name.
server {
listen 80;
listen [::]:80;
server_name your_domain www.your_domain;
index index.php index.html index.htm;
root /var/www/html;
location ~ /.well-known/acme-challenge {
allow all;
root /var/www/html;
location / {
try_files $uri $uri/ /index.php$is_args$args;
location ~ \.php$ {
try_files $uri =404;
fastcgi_split_path_info ^(.+\.php)(/.+)$;
fastcgi_pass wordpress:9000;
fastcgi_index index.php;
include fastcgi_params;
fastcgi_param SCRIPT_FILENAME $document_root$fastcgi_script_name;
fastcgi_param PATH_INFO $fastcgi_path_info;
location ~ /\.ht {
deny all;
location = /favicon.ico {
log_not_found off; access_log off;
location = /robots.txt {
log_not_found off; access_log off; allow all;
location ~* \.(css|gif|ico|jpeg|jpg|js|png)$ {
expires max;
log_not_found off;
2.4 Creating docker-compose
nano docker-compose.yml
2.5 creating env file
nano .env
2.6 paste the following in .env file and remember to change the values
MYSQL_ROOT_PASSWORD=your_root_password
MYSQL_USER=your_wordpress_database_user
MYSQL_PASSWORD=your_wordpress_database_password
2.7 creating docker-compose( remember to change "your-emailaddress@gmail.com" to your email address)
version: '3'
services:
  db:
    image: mysql:8.0
    container_name: db
    restart: unless-stopped
    env_file: .env
    environment:
      - MYSQL_DATABASE=wordpress
    volumes:
      - dbdata:/var/lib/mysql
    command: '--default-authentication-plugin=mysql_native_password'
    networks:
      - app-network
  wordpress:
    depends_on:
      - db
    image: wordpress:5.1.1-fpm-alpine
    container_name: wordpress
    env_file: .env
    environment:
      - WORDPRESS_DB_HOST=db:3306
      - WORDPRESS_DB_USER=$MYSQL_USER
      - WORDPRESS_DB_PASSWORD=$MYSQL_PASSWORD
      - WORDPRESS_DB_NAME=wordpress
    volumes:
      - wordpress:/var/www/html
    networks:
      - app-network
  webserver:
    depends_on:
      - wordpress
    image: nginx:1.15.12-alpine
    container_name: webserver
    ports:
      - "80:80"
      - "443:443"
    volumes:
      - ./nginx-conf:/etc/nginx/conf.d
      - certbot-etc:/etc/letsencrypt
    networks:
      - app-network
  certbot:
    depends_on:
      - webserver
    image: certbot/certbot
    container_name: certbot
    volumes:
    command: certonly --webroot --webroot-path=/var/www/html --email your-emailaddress@gmail.com --agree-tos --no-eff-email --force-renewal -d your_domain -d www.your_domain
volumes:
  certbot-etc:
  wordpress:
  dbdata:
networks:
  app-network:
    driver: bridge
2.8 Finally run
sudo docker-compose up -d
Step 3: Installing WordPress
3.1 open a browser and type
https://your_domain_name.example
3.2 Follow the on screen instructions to finish the installation.
Step 4: Installation Screen
4.1 Click on continue
Step 5: Installation
5.1 Enter the required details
Step 6: Admin Panel
6.1 This is your admin panel, here you can configure your WordPress site.
