Working Rubik's Cube on Google SketchUp
Intro: Working Rubik's Cube on Google SketchUp
What you will need:
- A computer capable of running Google SketchUp
- The free program Google SketchUp, which can be downloaded right here: http://www.sketchup.com/
Have Fun!
STEP 1: Step One: Making the Segments
STEP 2: Building the Cube
Now that you have your cube segment as a component, it is time to copy and paste them together into a 3x3x3 cube. Select the component you have just made and copy (using Command+c for Mac, or Control+c for Windows), and paste it (using Command+v for Mac, or Control+v for Windows), to make another. Use the Move tool to grab this by a vertex and move it to another vertex on the original segment so they are joined together. Do this again to create a row of three segments. Now, deselect, and select the entire row, and copy, paste and move it twice to create the bottom third of the cube. Now, deselect and select the entire bottom third, and copy, paste and move it twice to complete the design of the cube.
STEP 3: Black Lining Around Segments (optional)
STEP 4: Creating the Axis Points.
Now that you have a model that looks like a standard, 3x3 Rubik's Cube, it's time to work out the rotation of the cube, so it can be mixed up and solved. What you need, are axis points for the cube to turn on. There are many ways to make these, but the simplest solution I could think of was using the Line tool to draw an X in every centre cube, so the intersection of the two lines would serve as an axis point. once you have done one of those on the centre cubes of each face, you are done building the cube.
STEP 5: Rotating and Playing With the Cube
Thanks for reading and enjoy your cube!
4 Comments
Super_doodles 8 years ago
It's a 3x3x3, not a 9x9x9. You can tell because there are 3 rows, 3 columns, and 3 layers deep. 3x3x3.
pineappleattack98 10 months ago
hotheriontroll 10 years ago
amandaghassaei 11 years ago
