Introduction: Winson WCS1700 Hall Effect Current Sensor Using Arduino Uno
This tutorial shows us how to read and print values of the Winson WCS1700 Hall Effect based linear current sensor onto a 4 digit seven segment display.
What you will need :
  1. Winson WCS 1700 Hall Effect based linear current sensor
  2. 4 Digit Seven Segment Display
  3. Arduino Uno
  4. Jumper wires and Bread Board
  5. Current Source
Step 1: Understanding the Connections of Winson WCS1700
Note :
  1. Capacitor C (0.01uF~0.1uF) is recommend to be connected between Vout and GND to reduce output noise
  2. There is an arrow at the top of the sensor which represents current direction, make sure to connect the wire in that direction itself
Step 2: Understanding the Connections of the Seven Segment Display
Step 3: Arduino C Code
The Arduino C code file being used is uploaded below.
Step 4: Final Output
There can be an offset in the values between the current source and the current senser due to noise generated in the environment.
For more information regarding the sale of these components check https://empere.in
Winson WCS1700 Current sensor : https://empere.in/product/through-hole-current-sensor-wcs1700/
Winson WCS1700 Current sensor data sheet : https://www.winson.com.tw/uploads/images/WCS1700.pdf
4 Digit Seven Segment Display : https://sourcewell.in/product/sd5641a-b-segment-display/
For more information regarding contact through email id at 'sales@empere.in' .
