Introduction: Workshop Storage
Sufficient and workable storage in a workshop is always a consideration. When I was working out of my garage, I never really got it right. When I purchased a 12x24' shed, I took the time to build in plenty of storage.
Step 1: Plenty of Bins
In your workshop, you need plenty of places to store nails of all kinds, screws, nuts and bolts, assorted hardware... All kinds of things. The easiest way of having enough storage is to build it in between the studs. I cut 1/2 inch plywood to 3 1/2 inches wide, long enough to fit between the studs. For my Instructable, each vertical column of bins was offset higher or lower than the one next to it by half an inch. That way, I could nail into the end of every bin bottom. (I glued around all four sides, as I wanted it to be able to hold the weight of the nails, etc. Plus, I couldn't nail the back of the bin bottom, as I would be nailing through the side of the building.) The front of each bin was made of a strip of paneling, cut to 2" high. I just nailed it straight across, despite the fact that some of the bins were half an inch higher. It just looked better that way.
Step 2: Pegboard
( Don't pay any attention to the electrical outlet - I hadn't completely finished wiring when I took the photos.)
Step 3: Miter Saw and Tool Storage
I wanted to have as little in the way of flat surfaces in my shop as necessary. If it is flat, I lay stuff on it. I made my miter saw table just barely larger than the saw, and on either side, I added power tool storage shelves. The top surfaces are covered with plastic laminate.
Not shown are the roller stands I move into place when I use the miter saw.
Step 4: Tool Buckets
In order to store the buckets, I made a rack to hold them vertically. I cut four D shaped pieces of plywood a couple of inches bigger than the bucket. I screwed a 1x12 piece of 5/8 plywood to a stud, and added cleats to hold the back of the D. I screwed 1x6 pieces of plywood to each side to hold it rigid.
