Woven Ring Pendant
Intro: Woven Ring Pendant
This pendant is composed of 7 wire rings, not including the jump ring. The rings are linked by mobius weave which means every ring passes through the others. More information for mobius weaving can be found here.
I got 25’ of 16 gage wire from a home improvement store for less than $2.00. You could also use a coat hanger.
Needed:
Wire
Solder
Needed:
Wire
Solder
STEP 1: Make Rings
Using a socket and pair of pliers wrap the wire into a coil. Use a pair of snips to cut the rings free.
STEP 2: Start Weaving
Link two rings together and lay them flat. Push them together so they’re “hugging”. Open a third ring and run it through the other two. Lay it flat and push it together.
Open a fourth ring and run it through the three others. Lay it flat and push it together.
Repeat the process until you have the desired amount of rings. I used 7.
STEP 3: Arrange and Solder
Place the assembly over a tapered shaft. I used the end of a prybay. Arrange the rings so that none of the openings show from the front. Apply flux to the rings and place a small piece of solder by each ring opening.
Solder the rings and wait for it to cool before handling.
For more info on soldering, flux and so on check out https://www.instructables.com/id/Phillips-Head-Stud-Earrings/
STEP 4: Jump Ring and Polish
Remove any left over sharp edges from the back of the pendant. Polish the pendant with polishing compound and a polishing wheel.
Make a jump ring using the same socket and pliers method. File the edges so that it closes nicely and attaché it through the pendant.
71 Comments
manman11 9 years ago
Thanks
michaelhoover 12 years ago
Tinker L 9 years ago
I love how this looks, but am intrigued with the idea of weaving rather than soldering. Can you please explain?
I love how this site gets the creative juices flowing!
Mrballeng 12 years ago
S.Leung 11 years ago
clazman 9 years ago
https://www.etsy.com/listing/104047973/copper-plating-solution-2-oz-bottle-by?utm_source=google&utm_medium=product_listing_promoted&utm_campaign=supplies-low-other&ione_adtype=pla&ione_creative=49918020875&ione_product_id=104047973&ione_product_partition_id=82464281555&ione_store_code=&ione_device=c&ione_product_channel=online&ione_merchant_id=12000801&ione_product_country=US&ione_product_language=en&gclid=CNGpq_TIzMMCFUdefgodylsA2A
HouseSlayer 9 years ago
This looks awesome and all but I was wondering how do you coil the wire so precisely. I am having problems with getting each wire circle aligned with the next leaving gaps and uneven circles when I clip the wire
Marvellous me 9 years ago
I and a friend turned it into a toy. I loved this, and the others you do. You can see mine at https://www.instructables.com/id/Ultimate-boredom-t... . It is fun to play with all the time.
suka.teater 9 years ago
i'm a beginner, so this will be a stupid question, i im gonna make it with the exact same material as you are. will it bend easily or.. something?
in short, this ring can be bend easily?
sorry for my bad english as i am a non-native speaker
ibob4tacoz 9 years ago
No, after you make the rings and solder (if done correctly), it should be very solid.
swise3 10 years ago
cxiong1 10 years ago
neilh 11 years ago
The pictures show it better.
neilh 12 years ago
Great instructable! Thanks!
Kryptonite 12 years ago
neilh 11 years ago
I just made another one and I may have a suggestion for you. Make sure that all the rings go through in the same direction, if you have one that is flipped around it wont sit right.
I learned that the hard way and then saw this: http://www.youtube.com/watch?v=erHeGSNDpXk
(not my video, it's from a shop in Canada that sells rings & such that I happened to find.)
Cheers.
bioboy725 11 years ago
Gooberz 12 years ago
