Introduction: Writing Desk Repair and Upcycle
About: Hi I'm Copperhead Makes and I spend my time creating items that I, my family or friends can enjoy. I love trying out new crafts and I'm always on the look out for my next big project.
This is different from my normal Instructables in that I'm really showing my thought process in repairing and upcycling a writing desk that was deemed for the skip. Unfortunately it was riddled with woodworm but I thought it was worth trying to save it as it looked in decent order. I want to encourage anyone taking on a project like this as the end result is so worth all the effort. So here's how I saved a beautiful writing desk from the skip.
Supplies and Hardware
Woodworm Killer spray - Amazon
Screws various sizes - Local Hardware store
Nails various sizes - Local Hardware store
Nuts and bolts various sizes - Local Hardware store
Map Paper (for decoupage) Essential Paper Packs - World Maps - www.hunkydorycrafts.co.uk
PVA Glue - Local Hardware store
Archive Handles x2 - Aliexpress
Gargoyle Handles x4 - Etsy
Gargoyle Key Escutcheon - Etsy
4x Drawer Slides - Aliexpress
2x cuphandles - Aliexpress
1x iron handle - Aliexpress
Plywood - B&Q
Smooth planed square edge whitewood timber L2.4m, W 44mm and T 12mm - B&Q
Matt Walnut Satin - B&Q
Anti-tipping furniture locks kit - Amazon
Tools Used
Syringe - Aliexpress
Paint Brushes - Aliexpress
Drill
Japanese Band Saw
Adjustable Spanner
Table Saw
Oscillating Saw
Mitre Saw
Step 1: Woodworm Treatment
I put the Writing Desk in my back garden so I could get started on getting rid of the wood worm. I bought a Woodworm Killer in spray bottle form that had good reviews on Amazon. Wearing gloves and a mask for safety I completely sprayed the unit. I also used a syringe with some of the woodworm formula in it and squeezed the solution into any holes I could see. Unfortunately there where a lot of holes in the two bottom drawers and the wood felt spongey. I made the decision to discard the two drawers and remove the bracer holding the top drawer in place. I then left the desk to dry for a few days.
Step 2: Adding the Bracer and Removing Letter Slots
I finally brought the desk into the house and started work on replacing the bracer with a new piece of whitewood timber that had the same thickness as the discarded woodworm riddled bracer. I took off the drop down lid and I also started removing some of the wooden letter slots from inside the desk. I would be using the desk to store my mini pc, keyboard and various hard drives so the slots would be in the way. I decided to keep the slots located on the left side intact as I wanted to use them to store my hard drives.
Step 3: Creating a Base
I decided to use the main part of the desk to house my laser printer and a section for important papers that I needed to keep. I measured the base of the unit and cut a piece of plywood to fit and screwed it in place. To access the laser printer and the paper section I came up with the idea to get them to both pull out of the desk for easy access. To do this I would first need to create two sections one for the laser printer and one for the file drawer.
Step 4: Laser Printer Section
I measured the height, width and depth of the laser printer to ensure it fitted inside the desk. I then took some measurements of the desk to ensure that I could fit both the laser printer and file drawer side by side. I measured the space I had for the laser printer and cut a rectangular piece of plywood to fit. I then screwed two drawer slides into the base of the desk. I fully extended the slides out and screwed the plywood to them. I then added a wrought iron handle to the edge of the plywood shelf to enable me to pull out the shelf. Using a hole cutter I cut a hole in the back of the desk and fed the laser printers plug through the hole. I then placed the laser printer on top of the shelf.
Step 5: File Drawer Section
I measured the height, width and depth of the section I had for the file drawer. I then checked to make sure I had enough space to use hanging drawer files. I measured and cut some plywood to form a rectangular box and using some strips of metal cut to size (I used two metal rulers) I screwed these to either side of the box to act as a rail for the hanging files. I then screwed two cup handles onto the front side of the drawer. Using heavy duty drawer slides I screwed these in place inside the desk, fully extended the slides and then screwed the drawer unit onto them.
Step 6: Paper Storage
Once I had finished the inside of the desk I realised height wise there was some space that could be utilised to store paper for the printer. I cut some ply to size, screwed it to together and using L shaped brackets screwed it to the desk. I then had an A4 metal drawer that I bought in Ikea that fitted the space.
Step 7: Installing Doors
Once the internal sections were built inside the base of the desk I then concentrated on creating doors for the unit. I measured the height and width of the space and divided it in two. I then cut some plywood into two squares to fit the space. As the plywood was plain I decided to add some wood moulding to make the doors more ornate. I measured and cut the wood moulding to size using a mitre saw to cut the 45 and -45 degree angles. I then attached them to the doors using panel pins and glue. Unfortunately there was a slight gap in the middle when the doors where closed together so I added wood moulding down the side of the door on the right. This ensured that when the doors where closed together the slight gap was hidden. I then measured and added some Gargoyle handles that I found on Etsy.
Step 8: Mini Drawers
As I said in Step 2 I removed the letter slots as they were of no use to me. I wanted to keep my keyboard and mini PC stored in the writing desk. I first removed the middle slot of the letter holder on the left hand side of the unit. I had kept three drawers that had been located under the letter slots and wanted to use these to house my hard drives and Usb sticks. I measured the space left by the removed letter slots and cut some plywood to create shelves for the drawers to sit on. Unfortunately there was a gap left above the top drawer so I decided to create a secret storage area. I cut a bit of timber (that I had left over from the bracer) and added some wood moulding to its edge with glue and panel pins. I then slotted this into place. This secret area will house my Usb sticks.
Step 9: Sanding & Painting
Once I had finished building the various sections and screwed the lid of the unit back on it was time to sand the unit. Once this chore was done I was ready to paint. As I had used various woods in this upcycle I decided to use a Matt Satin Walnut paint to get an even colour over the entire desk.
Step 10: Keys
Once the paint was dry I added sticky back felt to the pull outs that the lid of the desk rests on. I also found a gargoyle escutcheon for the lid keyhole which I screwed into place. I had no keys to lock up the unit but my partner was working on a steampunk project and had bought a job lot of old keys. After trying a bunch of them I luckily found a key that worked so I am able to lock the lid and the drawer on the writing desk.
Step 11: Decoupage
I wasn't happy with the overall look of the writing desk, I felt something was missing, so I decided to do some decoupage on certain areas of the unit. I ripped up some map papers I had bought for another project and using matt Modge Podge I decoupaged certain areas of the unit. To accommodate my mini PC and keyboard I drilled a hole into the back of the writing desk so I could feed the wires through.
Step 12: New Section Add On
I decided to add and extra unit on top of the writing desk. This was simply because I had a lot of plywood left over and wanted to use it up. I measured the width and depth of the top of the unit and cut the plywood to size. I screwed the plywood together leaving two sections either end for drawers I had salvaged from another project. I added some archive handles to the drawers. I would have used the Gargoyle handles I had used on the writing desk to give a more cohesive look to the unit but I only had the four. To ensure that the desk wouldn't topple when I used the writing desk I used Anti-tipping furniture locks for safety.
Step 13: Finished
I am really happy with how the writing desk turned out and I hope this will encourage you in the future to maybe save a piece of furniture destined for the skip. Happy Crafting!
