Introduction: X415 K'nexterminator Machine Gun
This is possibly the first detailed Knex machine gun here. this gun is pretty powerful, firing at a good 1100 RPM, depending on what motor you use.
Pieces
x=# of chainlinks
Rubberbands: x+2
One-slot connectors(gray):4x+1
White rods: x+47
Yellow rods: x+23
Blue rods: x+31
Orange 2-slot connectors: 4x+40
Chainlinks: x
Gray rods: 21
Wire/string: 16"
White connectors: 23
Yellow 5-Slot Connectors: 16
Green 4-Slot Connectors: 27
Green Rods: 58
Red 3-Slot Connectors:36
Silver Spacers: 66
Blue Spacers: 20
Red Rods: 10
Motors: 1
Red Gears: 3
Gold Gears: 1
Blue 7-Slot 3D Connectors: 18
Purple 4-Slot 3D Connectors: 4
Tabbed Brown Connectors: 5
Total: 452 Pieces!!
Pieces
x=# of chainlinks
Rubberbands: x+2
White rods: x+47
Yellow rods: x+23
Blue rods: x+31
Chainlinks: x
Gray rods: 21
Wire/string: 16"
Green Rods: 58
Silver Spacers: 66
Blue Spacers: 20
Red Rods: 10
Motors: 1
Red Gears: 3
Gold Gears: 1
Total: 452 Pieces!!
Step 1: Chain Links
These are the basic "barrels". Make as many as desired
Pieces:
1 rubberband
4 One-slot connectors(gray)
1 white rod
1 Yellow rod
1 blue rod
4 orange 2-slot connectors
1 chainlink
Pieces:
1 rubberband
1 white rod
1 Yellow rod
1 blue rod
1 chainlink
Step 2: Build the First Front Piece
The first frontish piece
Build 5 gray rods connected to white rods (pics 2+3)
Pieces:
5 Gray rods
5 Orange 2-Slot connectors
5 white rods
2 blue rods
2 yellow rods
1 Yellow/Gray 5-Slot connector
2 Green 4-Slot connectors
Pieces:
5 Gray rods
5 white rods
2 blue rods
2 yellow rods
Step 3: Build the Second Front Piece
The second frontish piece
Slightly more difficult
Pieces:
4 orange connectors
1 blue 3d connector
1 purple 3d connector
2 Yellow rods
1 commando connector (wierd black piece)
2 Red rods
2 Yellow/orange connectors
1 Blue Rod
6 green rods
2 Red/Granite connectors
3 White rods
Pieces:
4 orange connectors
1 blue 3d connector
2 Yellow rods
2 Red rods
1 Blue Rod
6 green rods
3 White rods
Step 4: Build Gear One
A complex gear.
Parts:
15 Silver Spacers
2 Commando connectors (wierd black things)
3 tabbed Brown connectors
3 Blue spacers
3 red gears
1 Orange 2-Slot Connector
2 Gray 2-slot connectors
2 red rods
1 Yellow rod
2 white 8-slot connectors
4 green rods
3 white rods
1 gray 1-slot connector
Parts:
15 Silver Spacers
3 Blue spacers
3 red gears
2 red rods
1 Yellow rod
4 green rods
3 white rods
Step 5: Assemble
You should now have 3 parts... 2 front and 1 gear
Step 6: The Trigger Handle
This is the part in the back
Pieces:
21 Red 3-slot connectors
12 Blue 3D connectors
13 White Rods
9 Blue rods
7 yellow rods
4 orange connectors
2 Yellow connectors
12 Green connectors
4 Silver spacers
8 blue spacers
Pieces:
13 White Rods
9 Blue rods
7 yellow rods
4 orange connectors
2 Yellow connectors
12 Green connectors
4 Silver spacers
8 blue spacers
Step 7: The Auxillary Handle
This is the front handle
Parts:
8 yellow rods
7 Red Connectors
4 Yellow connectors
6 Blue Rods
8 white rods
5 green connectors
Parts:
8 yellow rods
7 Red Connectors
4 Yellow connectors
6 Blue Rods
8 white rods
5 green connectors
Step 8: Build Gear Two
This is a simpler gear
Pieces:
4 White 8-slot connectors
1 motor, Large
7 Silver spacers
14 green rods
1 Gold gear
2 tabbed brown connectors
2 blue spacers
2 Gray 1-slot connectors
Pieces:
1 motor, Large
7 Silver spacers
14 green rods
1 Gold gear
2 blue spacers
Step 9: Build the Bar Thingies
Build these two.
Pieces:
2 White 8-slot connectors
2 Orange 2-slot connectors
2 Yellow 5-slot connectors
4 blue rods
4 silver spacers
Pieces:
4 blue rods
4 silver spacers
Step 10: Build the Middle Connector
A thing in the middle
Pieces:
5 White 8-slot connectors
2 blue rods
2 blue 3D connectors
1 Green 4-slot connector
2 white rods
1 purple 3D Connector
7 Green rods
Pieces:
2 blue rods
2 white rods
7 Green rods
Step 11: Assemble Again
Now you should have some parts...
Get the first assembled part, The two bar thingies, and the front connector
Step 12: Build Two Pieces
Build the first and second things
Parts:
3 grey rods
1 White 8-slot connector
3 orange 2-slot connectors
1 white rod
3 green rods
Parts:
3 grey rods
1 white rod
3 green rods
Step 13: Build the Block Mechanism
This will stop the motor from spinning.
Pieces:
29 Silver spacers
3 blue connectors
7 blue spacers
10 orange 2-slot connectors
5 white connectors
1 red rod
1 yellow rod
1 rubber band
Pieces:
29 Silver spacers
3 blue connectors
7 blue spacers
5 white connectors
1 red rod
1 yellow rod
1 rubber band
Step 14: Build and Attach the Bottom of the Aux. Handle
Parts:
4 Gray rods
5 Green connectors
3 Yellow rods
1 blue rod
3 orange connectors
2 yellow connectors
3 green rods
2 blue 3d connectors
2 purple 3d connectors
4 Gray rods
5 Green connectors
3 Yellow rods
1 blue rod
3 orange connectors
2 yellow connectors
3 green rods
Step 15: More Attaching
Attach the block mechanism and the thingy made in step 12
Then Attach gear 2
Then Attach gear 2
Step 16: The Block Mechanism to Trigger Connector
You'll build a part now
Nevermind the wire yet
Keep the hinge to the side now.
Pieces:
5 Blue Rods
1 red rod
1 Gray rod
7 Orange Connectors
1 Green connector
4 Red 3-slot connectors
3 yellow connectors
8 green rods
1 Green connector
3 silver spacers
1 Yellow rod
1 Hinge(blue and black)
1 white rod
Pieces:
5 Blue Rods
1 red rod
1 Gray rod
7 Orange Connectors
1 Green connector
3 yellow connectors
8 green rods
1 Green connector
3 silver spacers
1 Yellow rod
1 white rod
Step 17: Build More Stuff
more things to build
keep the first thing to the side
Same with the second
Pieces:
2 Grey rods
1 orande connector
1 yellow rod
3 green rods
1 blue rod
1 blue 3d connector
1 green connector
Pieces:
2 Grey rods
1 orande connector
1 yellow rod
3 green rods
1 blue rod
1 blue 3d connector
1 green connector
Step 18: Build the Back Connector Plate
The Back Plate
Pieces:
4 Red Rods
9 green rods
3 gray rods
5 White rods
3 Red Connectors
Pieces:
4 Red Rods
9 green rods
3 gray rods
5 White rods
3 Red Connectors
Step 19: Final Attatching
Get ready for a !!LOT!!of attaching
Attach he back plate and one the thingies from step 17 (2+3)
attach the back plate and the trigger(4)
Then Attach step 16(5)
Then Fit The two huge chunks together... sorry that part isnt very detailed but it's simple enough when you look at the pictures and the whole pictures.
Then attach the Hinge thingy
And Attach step 12
And Attach step 12
Step 20: Rubber Bands and Wire
Now the finishing touches...
Pieces:
16" of wire or string, or less.
1 rubber band
Attach a rubberband to the trigger
Pieces:
1 rubber band
Step 21: Optional Display Tripod
This is optional. Alas, you can't shoot with it, as it blocks the chain. It works well for display, though.
You have to modify the gun slightly for the stand. It's a matter of about 3 pieces however so you needn't worry
Pieces to change:
1 Yellow 5-slot connector
1 Purple 3d connector
1 blue 3d connector
Pieces:
4 White connectors
5 Red 3-slot connectors
4 gray 2-slot connectors
9 Gray rods
2 Yellow rods
2 silver spacers
2 blue spacers
3 blue rods
1 blue 3d connector
3 green rods
Pieces to change:
1 blue 3d connector
Pieces:
4 White connectors
9 Gray rods
2 Yellow rods
2 silver spacers
2 blue spacers
3 blue rods
1 blue 3d connector
3 green rods
Step 22: Loading and Firing
Loading and firing is simple
Pull, place, and load!
Take off top, put on chain, put on top!
Now push the black arrow up,
And pull the trigger to fire!!
