Introduction: X8R Trade Consumables Organisers
The Fault
Lack of storage solutions available from factory options in commercial vehicles
Most commercial vehicles, van and camper conversions have limited storage solutions. They often come with the rear of the vehicle completely bare except from the MDF cladding on the inside of the shell.
Our Solution
Install X8R’s universal trade consumables organiser brackets can be installed in under 5 minutes for a simple storage solution.
X8R’s consumable organiser brackets are the perfect solution for tradespeople such as carpenters, electricians, plumbers, decorators, mobile mechanics and more. The holders can be fitted using self-tapping screws for an easy installation (no power tools required, although you can use an electric drill if you wish) in under 5 minutes.
The brackets could also be wall-mounted such as in garages etc. Please ensure you use suitable wall plugs.
The brackets are made from 1.5mm thick black powder coated steel, a far superior material versus the inferior plastic other solutions which often break.
Compatibility
The XL Wipe & Boxed Glove bracket is compatible with the following:
- Uniwipe Ultragrime (all varieties)
- All boxed gloves with a width of 23cm or less
The Cylinder Wipe bracket is compatible with the following:
- Big Wipes
- Wonder Wipes
- DirtEeze
And all other cylinder wipes with a diameter of 117mm or less.
The Caulk, Silicone, Adhesive & Gun bracket is compatible with all caulk, silicone, adhesive tubes etc with a diameter of 2 inches or less, with space for the gun on the far right hand side.
You will need:
- Self tapping screws (we recommend 3.5 x 16mm self tapping screws)
- Screw driver or electric drill
- Spirit level
- Marker
Step 1:
Press the bracket against the wall you're fitting it to. Ensure it is level with a spirit level. Mark the holes with a pen.
Use a screwdriver or electric drill to fit the screws into the holes.
This completes the installation. If you need any further guidance on this install or would like to purchase the parts shown please call us on +44 01843 446643 or email us at sales@x8r.co.uk. Please also check out our instruction guide on YouTube. www.x8r.co.uk Installation is carried out at installers risk, if unsure please contact us or a professional, X8R Ltd cannot be held responsible for any adverse result of installing this product or any injuries caused by install, if in doubt ask a professional. All images and texts are copyright X8R Ltd 2024.
