Success at last!!! Do not be scared to dig into your machine! (If the warranty has run out) Mine looks like a beaver chewed on the back for awhile its been opened and closed so many times! (the hardest part is openng and closing the cabinet!) The bolt fix never worked for me but I just bent the x-cross's that hold the GPU and heat sink abit more. Did everything according to the video but after heat up I left it in the steel cabinet and then tightened down the 8 screws that hold the cross's into the steel cabinet. When you get it apart you'll see what I mean. Let it cool down for an hour, put it back together, and game on!! YAH!! I did use a good helping of nexxtech heat sink compound when I put the heatsink and GPU back on though. Xbox 360 is tough! The mother board has seen printer head cleaner, a couple of blasts of ether (starting fluid) Damp paper towel and not very kind handling! Don't get too carried away though! lol Long live xbox 360!!!
yes, they are durable aren't they? mine was set fire to and the only thing that messed up was the cd tray, and the eject button is useless now, doesn't work. it had to have been on fire for a while too, almost burned down a camper (drunk guy lit a candle and then went to slepp)
well it worked but, I didn't apply do thermal compound and left on do x-clamp
it showed 2 red lights after a while .then i cooled it 4 an hr.wen i put it on 2 red keeps appering, wats ur advise on dis?
if you get an answer besides send it in i'd really like to know one of my three xbox's (one rrod, one that overheats instantly-two red lights- and a working one) has that issue, probably cause it was literally on fire, had to replace the disc drive, swapped PCB out for my old one since they were the same model drive, and turn it on and less than thirty seconds it flashes two red lights, gonna try this on it, since i cant mess it up anymore than it is now
My xbox had the 3 red lights and I decided to fix it by removing the x-clamps and replacing them with screws, long story short I scratched the motherboard just slightly, twice. The console still gives me 3 red lights, does this mean that I didn't mess up the motherboard (I assumed I'd get 4 red lights then)?
four lights is most likely the AV cables aren't plugged in, or the graphics card is shot, two is overheating, one is E74, or E73 idr what one, three is of course the infamous RROD
oh well they still wont even touch it bc it has been "tampered" with. my advice is to send it to game stop to fix or maybe you didnt "scratch" your motherboard... did u remember to overheat without the fans and get the 2 red light error before letting it cool and then trying to fire it up? bc that step is what gets rid of the error... it resets itself on the cool down
My xbox is actually working now, the thing is it has a desktop fan cooling it :). It is not very practical but I'm gonna replace the stock fans and look into placing a real fan over the CPU heatsink but that requires soldering and cutting :S
lol do you think if you took your xbox apart but when you put it back together you put the sticker back on Microsoft would notice when you sent it for repair??
yeah, unless somehow you get the tamper sticker perfectly back on, no corners peeled up or bent from being pulled on, its usually obvious when tamper proof stuff is messed with (not always, some things i can or have seen cheated)
You do know that by opening up the Xbox, you void the warranty, right? That means that if something else happens to your box and you can't fix it, you can't send it to Microsoft for them to repair. You'd have to buy a brand new box.
Of course, this method is perfect for those people who have expired warranties.
Your privacy is important to us, so please take a moment to indicate if we may collect and use your data.
We want you to have a good experience with us. To do this, we collect data about your online behavior or attributes and use advanced data analysis so that we may deliver new versions of our sites with customized content.
55 Comments
savior 15 years ago
blaze.ninja42.0 11 years ago
fazil 15 years ago
miss_ashley 15 years ago
Fridge Gnome 14 years ago
2 2=5 14 years ago
2 2=5 14 years ago
rolandbassett 14 years ago
2 2=5 14 years ago
2 2=5 14 years ago
egammoc 13 years ago
ONLY DO THIS IF YOUR XBOX'S WARRANTY IS OUT
joelyboy94 12 years ago
BiosTerminator 12 years ago
KingDubya 16 years ago
WhiteTigerTails 13 years ago
