Introduction: Fix the RROD on the Xbox 360 (something New)
Hi, I decided to make this instructable because like everyone else, i got the dreaded Red Ring Of Death. I did tons of research to find out what other people have done to get some ideas. After searching the web I found a few ways to fix the x-clamp problem, and the mother board flexing issue. I really liked the hybrid fix which used a plate with two 4mm foam pads that applied an even amount of pressure underneath the processors. I approached it a little different, I used a 1/8 in plate behind the gpu with foam that is normally used for poster backing; it was 4mm thick and worked great. I bought the screws from a local hardware store, and the plate was cut from a electrical outlet box. This plate is much thicker than the one used in the hybrid fix, making it impossible for the board to flex assuring a good connection under the gpu. Now i didn't re-flow it, or re-ball it because its to expensive; makes more sense to just buy a slim.
Step 1: Cooling the Gpu
So when it came to keeping the gpu cool I decided to do something different. I searched for hours trying to find someone who extended the cooling shroud with fans; creating a cold air inlet. So I purchased two mini fans from radio shack and constructed a front-end shroud out of card board and hot glue. This took a couple hours because it was very intricate and needed to be the perfect shape, and fit around all the existing components. It came out perfect and pushed a lot of air over the gpu heat sink, all on its own. Once connected to the rear fan they created a huge flow of air over the heat sink and kept it very cool; one pulling cold air in, and the other pushing it out the back. I also did the 12volt modd with two 150 ohm resistors ran in parallel.
Step 2:
then to finish it off i cut a hole on the top and used some screen i found at a local surplus store. Also, I cut the grill for the rear fans because they restrict a lot of air. My Xbox has been working great for months, and for many hours at a time. Please leave feed back, I would love to here it. Thank you
