Introduction: Xbox 360 Halo 3 Edition
When I was younger let's say. If i didn't have smoething like a game console. I would make it out of paper. So When iheard about the Xbox 360 halo 3 edition( I had just joined Instructables.) I thaought I should make a papper xbox 360 halo 3 edition and put it into instructables. So her is my final masterpeice of the xbox 360 halo 3 edition. And if you want to make one here's what you'll need.
Materials:
1. Siccors
2. thin cardboard
3. tape
4. a ruler
5. pencils
6. a pen
7. green construction paper
8. orange construction paper
9. your imagination.
Materials:
1. Siccors
2. thin cardboard
3. tape
4. a ruler
5. pencils
6. a pen
Step 1: The Supports and Sides
Take the thin card board and cut it into thin strips thatare an inch think. The take the ruler and measure it and mark the middle. then cut a lin in three of them. There should be on long stripp with two cuts in it. Then there should be two short strips, with cuts in them. then take two peices of green paper. Put them on top of each other, and roll them up tight.
Step 2: Putting the Everything Together
first you need to take printer paper and cut out a peice that is 3" wide and 9" long. Color that black. Then take another piece color that black. But you need to make it so it will be at a different level than the other one. Next you need to take the orange paper and cut a skiny rectable to fit in teh center of the raised up part with space on the side. Now you need to cut a long skinny oarnge rectangle but on one side curve cut it down. You need to make two of these. one for each side.
Then for the sides of the main part. You need to cut 2 green strips 3" wide. and put a curve on the sides. Then you have to put it all together and it should look something like this.
then break out the tape.
Step 3: The Finishing Touches
Then when you have that all together. you need to draw somethings on it.
Materials:
1. black marker
2. Orange constrution paper.
take the orange paper and cut it about 1 cm. wide and the whole page length. Then cut that down to the size of a disk, but keep and extra 1 cm. Now on that extra draw the eject button. In the part next to that write xbox. Now under neath that you should draw 4 skinny oalvals.
Now at the bottum of the orange draw a circle about 2 cm down.
When you finish it shou look like.
Materials:
1. black marker
