Introduction: Yagi Antenna 5 8GHz
In this video I will show you have to build a Yagi antenna for 5.8GHz. It is quite small but if you follow the methods I use you should have no problem building your own. The Yagi has just 5 parasitic elements but this ensures it has a wider beam angle although in having a wider beam doe’s sacrifice range. You can if you wish add more parasitic elements using the same measurements.
