Introduction: Yarn Bracelet
You will need 4-6 colors if you want multicolored.
Step 1:
Pick your colors of yarn and cut to fit wrist.
Step 2:
Tie a knot on one end and separate your colors.
Step 3:
Keep 2 strands in the middle to work around. Measure to your wrist or desired length and tie a knot.
Step 4:
I started on the left. Take your strands under the middle strands and thru the 2 strands on the right. You can start on either side.
Step 5:
Take the strand on top of the right and go under the middle strands and between the 2 on the left and over the top. Same as step 4.
Step 6:
Continue alternating strands till you get to the end, where the knot is.
Step 7:
Once you get to the end, tie your strands together in a knot.
Step 8:
You can also tie the ends together for the finish or you can put it on a buckle.
