Introduction: Yo-yo Flower Pot
These flower pots {yo-yo pots} are super easy to make, extremely versatile and super adorable. You can customize the flower/yo-yo pots to suit your style and/or needs.
Step 1: Fail at Gardening
So you bought seeds to plant and they grew, but then one of the following scenarios happened:
Thus, the first step: admit you have multiple problems. Then trash the dry, potentially molding, bug-infested soil from those planters and sanitize!
- They shriveled up despite proper watering
- The guy that cuts the lawn at your apartment air-headedly decapitated your two-foot tall zinnias
- Some mysterious insect decided to nom-nom the leaves
- You decided to skip the seeds, get some, say, red bell peppers, dahlias and lilies from your local hardware store on separate occasions; after the third plant dies you have decided that growing plants isn't your thing--or that the hardware store's greenhouse doesn't know what they're doing.
Step 2: Pick the Container
Any sort of planter will do just fine. For starters, I recommend something shallow, small and ceramic in order to maximize cuteness. Try to avoid vases with a narrow opening.
I got this 2" ceramic pot in a pack of 10 for 2.99 at Goodwill. Did I mention these are also cheap to make?
Step 3: Pick the Fabric
You can get quilting fabric for super cheap and it's easy to sew. "Fat quarters" (18"x22", a quarter of a yard and half the fabric width) are a nice option as well because you can choose from a variety of patterns without the commitment of fabric by the yard.
The final size will be roughly half the size of the circle you make. Example: 4" diameter circle = 2" diameter yo-yo. Simple enough. Because yo-yos can be as small or as big as you want, varying the sizes of each yo-yo can make your "arrangement" more interesting.
For this example, I'll be using three yo-yos; two yo-yos with solid fabric and one with patterned fabric to accent the others.
Step 4: Pick Coordinating Thread
The title of this step says it. The thread really won't be showing but in case it does, it's nice that it matches.
Step 5: The Other Supplies
These items are available at craft stores:
- Fake moss
- Styrofoam
- Glue - hot or all
- Needle
- Floral wire, pipe cleaners, twigs, or whatever you think will properly erect your yo-yo
- Scissors
- Cardboard for circle template
Step 6: Cut Circles
Trace different sized circles onto cardboard, then use them as templates for the fabric. Anything round - a CD, a roll of masking tape, a bottle, etc. You get the idea.
Step 7: Fold
Fold the edge over about 1/4".
Step 8: Backstitch and Knot
Sew through the top of the fold. Then go through the same spot again (backstitch) and tie a knot to secure the thread.
Step 9: Sew
Sew a running stitch all the way around the top of the folded edge. When you get to the first stitch, pull the thread so the circle gathers.
Note: The shorter you make the stitch--the wider the opening in the finished yo-yo. A longer stitch will result in a tighter yo-yo.
Step 10: Finish the Yo-yo
Finish by tying another knot close to your starting point. Flatten the yo-yo.
Step 11: Wire
The wire will support the yo-yo.
- Cut a very small slit, just big enough to slide the wire into.
- Cut about 6" of wire and shape it like a question-mark.
- Slide the end of the circled side into the small slit until only the straight end is showing.
Step 12: Assemble the Pot
Line the pot with glue and place (or jam) a circular piece of foam in the pot. Next, cut a circle of fake moss and glue it to foam.
Step 13: Arrange the Yo-Yos
Stick your yo-yo's through the moss and into the underlying styrofoam.
You did it! Now be amazed at how precious your final result is.
