Introduction: Your First 3d Print (toothbrush Holder)
3d print an object(toothbrush holder) from thingiverse.com
Step 1:
1. Dowload an .stl file from http://www.thingiverse.com/
Step 2:
2. Open the .stl file in makerware:
http://www.makerbot.com/makerware/
Step 3:
3. position object
rotate
select move> on platform
select turn> lay flat
rotate
Step 4:
4. Review settings in makerware
select make button
export for: replicator 2
raft: checked if you want a small bed on which to print, reduces curling
select make button
Step 5:
5. Export gcode file to sd card
export>save
make sure .x3g is chosen for file type
make sure location is sd card
export>save
Step 6:
6. Put sd card in 3d printer
push down and it will click
btw printer on/off button is at rear of printer
Step 7:
7. Print file from sd card
use the 3d printer menu
print from sd>toothbrushholder2
I made it at TechShop
