Introduction: ZOOM Mic Kill-Switch
On a ZOOM call...Kids rampaging through the house?...Dog starts barking?...Lunch burrito repeating on you?
Mute the mic.
This $8 Emergency Mute button makes it quick and easy. No fumbling with the mouse through 6 open Excel docs to find the mute button on the computer. SMASH the big red button on your desk. Stay in your meeting without embarrassing background antics.
I have a separate mic from my webcam - but this can kill both if it you use a webcam for both audio and video out. (...when your significant other wanders through the background in their skivvies)
Reset the switch and the computer re-discovers the USB device(s) - carry on with your meeting.
Needed:
- Kill switch (https://www.amazon.com/gp/product/B07JJDCK9F/ref=p...)
- USB extension cable
**ACTIVATION LED OPTIONAL**
- LED (built in resistor)
- x3 - LR1130 batteries
Step 1: USB Extension
Side 1 - Red
Tackling this one side of the breaker at a time - let's start with the USB Extension.
Expose a section of the USB cable. Do NOT cut the wires within.
Step 2: 5 Volt Wire
The red wire is the 5v power. Cut only this wire and strip the ends.
Step 3: Connect USB Extension
There are 2 sets of poles - NO (Normal Open - Green) and NC (Normal Closed - Red). When you hit the big red button, NC/Red side turns off a connection - NO/Green turns on a connection. We're going to kill the USB mic (NC/Red) and turn on the LED (NO/Green).
Connect the USB red wire leads to each side of the NC/Red poles.
(not pictured - electrical tape around the remaining exposed USB wires to prevent unintentional grounding)
Step 4: LED / Battery Compartment - **ACTIVATION LED IS OPTIONAL**
Side 2 - Green
I picked up a super bright red LED (with built in resistor) and 3D printed a battery compartment that fits x3 LR1130 batteries.
I removed the USB cable so these steps would have fewer wires and look less confusing
(LEDs and battery pack leads from Amazon - battery compartment .stl provided below)
Step 5: Set the LED
I'm going to sacrifice one of the beveled screw hole to set the LED.
Step 6: Wire Path
On the inside of the unit, I created a small canal with a Dremel to run the wires from the screw hole to the breaker.
Step 7: Solder
** MIND POSITIVE and NEGATIVE **
After confirming the positive and negative poles, I solder the wires in place on the battery compartment. One wire from the LED and one small 3" length of wire.
Step 8: Set Compartment
The 3D printed compartment is a snug fit - so just a bit of Super Glue to lock it in place.
(moved the compartment from the side, to the end of the switch - more room for battery leads)
Step 9: Connect LED
Connect the remaining wire from the LED to a NO/Green pole. Also connect the 3" wire from the battery compartment to the other NO/Green pole.
Reconnect USB wires to NC/Red poles (step 3).
Step 10: Button It Up
Set the remaining 3 corner screws - plug your mic (or webcam) into the female end of the USB extension cable - plug the male end of the USB extension cable into your computer.
Step 11:
Mic Kill - Reset
