Zelio PLC
Intro: Zelio PLC
Zelio PLC is a very interesting controller device from Schneider company and so easy to use and useful if you don't have a time or knowledge with micro controller but it is a little bit expensive comparing with Micro Controller.
there are many type of Zelio PLC depending on Number of input and output, the smallest one shown in below picture.
it contain from :
4 digital input (I1,I2,I3,I4).
4 analogue input from 0-10 volt (IB,IC,ID,IE) .
4 output (Q1,Q2.Q3,Q4).
available power power source (12 ,24 volt DC) and (100,240 volt AC) it depend on your requirement .
the cost of this type about 130 $ plus configuration cable 50 $ .
the software used for this PLC called (Zelio Soft 2) ,it support LDR (ladder language) and FBD (function block diagram) with full simulator.
it contain from :
STEP 1: Switch on /Off
This Video showing how to use Zeliosoft to make a simple switch .
a Push button switch connected to I1 and two LEDs in Q1 & Q4 .
STEP 2: Analogue to Digital (ADC) Example
In this example a 10 K ohm variable resistance connected to Ib and the other pin to positive and 4 LED connected to Q1,Q2,Q3 and Q4 .
in the first circuit I define 5 volt as reference voltage and I compare it with Ib ,so if Ib more than or equal 5 volt ,Q1 will turn on.
in the 2nd circuit I define four reference 5,6,7,8 volt ,so when Ib equal or more than the reference value it will turn on Q1,Q2,Q3 and Q4
STEP 3: Impulse Relay Example
In this Example I1 connected to push button and impulse relay activated in Q1 &Q2 ,when push button clicked Q1&Q2 on ,when the Push button clicked again Q1&Q2 off.
I2 connected to magnetometer sensor like for the door sensor ,when the door closed Q3,Q4 turn off ,when door open Q3,Q4 on.
STEP 4: Text Example
I2 connected to Door magnetometer sensor ,if the door open Q1 will be on and Door Open text will appear on PLC LCD.
TX (enable text).
RX (reset text).
TX (enable text).
RX (reset text).
STEP 5: Counter Example
In this example 10 click on the push button will turn on Q1.
STEP 6: Timer Example
When push button pressed for 3 sec Q4 will turn on.
3 Comments
cartiman 9 years ago
thank you for the information.
I want to buy Zelio PLC, and for sharing in my blog about the PLC
amandaghassaei 11 years ago
Husham Samir 11 years ago
