Introduction: Zen Bulb
I recently ended up in possession of a very large, blown bulb.
I have seen several terrarium and ecosystem projects with old bulbs but I wanted something a little more interactive.
Step 1: Hollow Out the Bulb
I started out by cutting the bottom off of the Edison screw, I hadn't realized that with this being a modern bulb that there would be a bunch of electronics inside.
I needed a larger opening than other projects so I opened the whole base carefully with my knife. I extracted the guts with a needle tip pliers and smashed out the filaments. There are tonnes of tutorials on cleaning out a bulb but one thing is certain, you need to be careful as nobody wants an evening in the hospital with a palm full of broken bulb.
Step 2: Balance Is Integral to Zen...
I is also vital as bulbs are generally rounded!
I had some sticky backed rubber feet. I always use 3 points of contact over 4 as 3 points are self leveling (4 can rock about and is hard to level)
Step 3: Make a Rake
Using some hors d'oeuvre skewers I made up a small wooden rake.
The handle is made of 3 pieces for strength and length to reach the other side of the bulb.
The spikes are the tips of the skewers. I needed to remove the points with my snips and it took some paring with my knife to get the rake through the opening.
Step 4: Fill With Stones and Zen Out
I poured in .5kg of small grey stones I got at the pet shop.
I installed the rake and then combed the stones until I felt relaxed.
I think it looks well on the desk and it looked even better on the window ledge catching the sunlight.
You can fill it with any colored stone or sand you wish and changing the media is as simple as pouring it out and refilling.
