Introduction: ZigBot Phase 1
This Instructables shows how to use XIAO dev board start building a tiny robot.
- Seeed Studio XIAO ESP32C6: https://www.seeedstudio.com/Seeed-Studio-XIAO-ESP32C6-p-5884.html
(Since all the XIAO dev board share same form factor, you can replace with any version of XIAO in your hand)
- DC 3V 6mm Gearbox Coreless Motor (1200 RPM option)
- 501230 Lipo Battery
- Two 8mm Nylon/Steel Balls
Step 1: What Is XIAO ESP32C6?
XIAO is Seeed Studio Series product of tiny dev board. ESP32C6 is one of the Espressif's MCU that support 2.4GHz Wi-Fi 6, BLE 5.0, Zigbee and Thread.
Ref.:
Step 2: What Is ZigBot?
I would like to build a robot that communicates with ZigBee, I will call it ZigBot.
Step 3: Chassis Design
Many STEAM robot use 2 motors and 1 universal/caster wheel in the chassis, And in most case 2 wheels are coaxial, but it is not the only design.
In my previous instructables:
- https://www.instructables.com/Robust-Remote-Toy-Car/
- https://www.instructables.com/TTGO-T-Watch-Robot/
In order to reduce chassis size, the motor wheels are not in the same axis. Both motor wheels paired with a caster wheel also can works fine.
ZigBot is the 3rd iteration of this chassis design and this is the smallest implementation.
Step 4: 3D Printing
Please download and 3D print the parts at Thingiverse:
Step 5: Soldering Work
This tiny high ratio gear motor rated at around 20 mA if not stalled, so I decide ZigBot abused the ESP32C6 GPIO direct drive the gear motors. So the required components are reduced and the soldering work is relatively simple.
Here are the connection summary:
XIAO
BAT+ -> Lipo battery +ve
BAT- -> Lipo battery -ve
D4, D5 -> Left motor
D8, D9 -> Right motor
Step 6: Assembly
Please follow the above video for assembly.
Step 7: Software Preparation
Currently only Development release support ESP32C6, please follow the arduino-esp32 installation guide to install Development release:
https://docs.espressif.com/projects/arduino-esp32/en/latest/installing.html
Step 8: Test Run
Please download the test run source at GitHub and open with Arduino IDE:
https://github.com/moononournation/XIAO_ESP32C6/tree/main/TestZigbot
The test run program just test the forward, backward and turning function and then will enter deep sleep.
I will further develop the ZigBot once Arduino-esp32 provide more ZigBee feature.
Note:
The battery power saving feature of XIAO ESP32C6 in deep sleep mode is really good, I can still run the test run by pressing reset button after a week!!
Step 9: What's Next?
This instructables is the first phase of building ZigBot, I am still exploring how ZigBee can communicate between multiple ZiBot and make interaction. Follow my Twitter (X.com) for latest news.
