Introduction: Zigzag Paper Chain
If you're at home due to COVID-19 and are looking for something fun to do, make a Zigzag Paper Chain! You can use almost any kind of paper and you probably have the rest of the supplies at home! Thanks to picklebums.com for teaching me how to make this!
Paper (not too stiff)
Pencil
Ruler
Scissors
Tape
Step 1: Mark Your Paper
I wanted to use bigger strips of paper so it would be easier to work with and easier for you to see. So I marked strips that were 2 inches wide and 8 inches long. But you can make them any size, as long as the width:length ratio is about 1:4 (you can practice some math!)
Step 2: Cut Your Strips
Cut out all your strips. You need an even number of strips, but the amount depends on what you want to use your chain for; I used about 50 strips to make a headband. (To make a bracelet, I cut 1 inch by 4 inch strips and used about 20 strips.)
Step 3: Fold the Strips
Fold each strip lengthwise (hotdog style), then horizontally (hamburger style).
Step 4: Folding the Chain - First Two Strips
Take 2 strips. Turn one (purple) sideways, with the fold on the right. Hold the other one (white) vertically, with the fold on the top. Sandwich the vertical (white) strip in between the sideways (purple) strip.
Fold up the top layer of the white strip so its outer edge meets the purple strip.Then fold the white strip up again.
Step 5: Flip It Over & Repeat
After folding, tape the edges together.
Step 6: Add a Third Strip
Slide a 3rd strip into the (white) loop. Pull it through the loop, leaving a little more than 1 inch (that will become the next loop so you want to make sure it's big enough to fit the next strip).
Fold the 3rd strip twice and tuck, like you did before.
Step 7: Flip It Over and Repeat
Step 8: Continue Adding Strips
Keep adding strips, folding and tucking.
Step 9: Joining the Ends
Be sure to use an even number of strips. To join the ends, slide the first strip into the last loop. Remove the tape so you can pull the strip through.
Step 10: Fold & Tuck the Last Strip
Step 11: Tuck the Loose Strip
Step 12: Flip It Over & Repeat
Step 13: You Did It!
You are done!
Try using different types and sizes of paper! You can even use candy (like Starburst) or gum wrappers!
