Introduction: Zip Ties Candle Holder
I found some old zip ties and tough that they where too good to be tossed, so a made a candle holder out of it!
This is a really easy instructable, you will only need:
old used zip ties (40 units or more)
knife
knife
Step 1: Disassemble the Zip Ties
If you do like me, and use old zip ties, you will have to disassemble them first. Its really easy! in the zip ties there is a stic or a pin that holds the zip tie in position, if you bend this away you will easy be able to drag out the zip tie
Step 2: Starting to Make the Candle Holder
I started off with five zip ties in center, and keep adding zip ties. I did not make a pattern, but you can.
the shape you will also decide for your self. I made no special shape. It is soon valentine so maybe you can make a hart out of it!
making the candle holder don't take long, but you will use a lot of zip ties!
Step 3: Applications
You are finished!
I will use it as a candle holder.
!!!! do not place hot pots on the candle holder !!!!
