Introduction: Zipper Paracord Bracelet
About: Craft addict Pug lover Spastic Free mind Artist for life Expert baker Photographer
The best paracord bracelet around
Step 1: The Say
Simple yet elegant this paracord bracelet is one of a kind invented by me you will love it
Step 2: Supplies
All you need: 2 pieces of paracord from tip of hand to nose 1 piece of paracord the circumference of your wrist doubled Then some more to tie a knot plus another two or three inches Lighter Scissors Measuring tape Plyers
Step 3: The Base
Take the wrist measured paracord fold in half and tie end
Step 4: The Start
Take one of the two other pieces of paracord and feed it through the top as so
Step 5: To the Half Point Check Mark
Weave it in and out like shown in the picture make sure to do it tight the loose picture is to show how it is woven do this to the half way point
Step 6: The Splice
Once at the middle of the paracord base you need to take the end of the string and cut it short then pull the middle of the paracord out take the second and last piece of paracord and pull the inside out a little as well put them together and melt with lighter and use plyers to make a smooth transition
Step 7: To the End
Keep weaving with the second color and leave a loop at the end put the paracord through the last weave cut short and melt and smooth to inside of bracelet
Step 8: The Knot
The string hanging off the knot needs to be set so cut it short then burn the end and use plyers to make it flat also the string hanging from the under the knot is shortened melted and smoothed to the inside of the bracelet
Step 9: How to Put On
Put around wrist and put the knot through the loop and have that part on the under part of your wrist and that's it
Step 10: Rock It
It is a easy wear and stays on as good as a buckle without the hard plastic feel
