Introduction: Zipper Pull Hacks
More than once in my life I've had the zipper pull break off on jackets and jeans. Now that I've learned these hacks I no longer fumble around in an embarassed manner or discard almost perfectly good clothing.
Step 1: Hack One
The first hack is to react to the emergency by grabbing the first object you see that can be threaded through the zipper. In this case it was a rubber band. It worked but had more give to it than I wanted.
Step 2: Hack Two.
The next object I grabbed was a wire tie. This worked and provided a little more stability but it still had a little more flexibility than was desirable.
Step 3: Hack Three
The next object I grabbed was a paper clip. It was definitely stiffer than the previous two and it added color so it would have remained in place had I not come across my final hack.
Step 4: Hack Four
I found a key ring in a drawer and, while it was a little more difficult to attach. it proved to be the best of the hacks. It was solid, stable and aesthetically more pleasing than the others.
