Introduction: ZIPPO TRICK: Magic Smack
#2 Knee hit and light
Step 1: How to Begin
Hold lighter by the cap with hand facing down and hinge to the left or right depending on which hand you use.
Step 2: The Flip
Unable sure that you have a nice grip on the cap so that when you flip it up the zippo will not come flying out of your hand..
Turn hand upside down so that the casing opens, exposing the flint and lighter... Stilling griping cap.....
Fingers should be pointed up, lighter should be opened
Step 3: Re-grip
Slightly loosen grip so that you can position your hand parallel to the floor and lighter can fall into the circular opening in between your fingers....
Quickly retighten your grip on the cap so that the lighter does not fall to far into your hand
Step 4: Push
You may need to let the lighter slide down a little bit further in order for this to work
Make sure that the flint wheel is up against the inside of your hand so that when you hit the bottom of the lighter it will roll, spark and light
Step 5: Lighting
I prefer to use my knee but just about any surface will work....
Smack the end of your lighter on a surface to push the rest of the lighter back through the opening between your fingers....
While being pushed through that opening the flint should roll and spark the wick.... Lighting your fire
Step 6: Finish
Snap the lighter shut anyway you can.... CONGRATULATIONS YOU CAN NOW DO THE TRICK
