Introduction: Zune Books
How to view text documents, such as books, on your zune.
Step 1: The Problem.
I had a dilemma, I wanted to listen to music on my Zune whilst reading a book. I used to do this my PSP. (I know, both considered "rejects") So I came up with this solution and I decided to share it.
Step 2: The Program.
You're going to want to download this program: jpegbook
It's off a japanese/chinese site, but the program itself is in English.
Step 3: The Settings.
Once you've downloaded and extracted the program, run it.
Hit ctrl+O load your document.
Make sure to then select an output folder, it has to already exist since the program wont create it for you.
You'll want click on "Edit" then "Full con fig". In the "Output Image Size", select Custom and set the width/hight to 320 and 240 like so...
Step 4: The Solution.
Now you take that folder add it the Zune MediaPlayer, or whatever it's called.
sync it, and you're ready to go. Before you start reading, go to settings. In pictures make sure the "Transitions" is set to 30 seconds, in case the slideshow gets turned on. And that the backlight auto-off is set to a high number.
