Introduction: Adding Photos to a Psp
In this instructable I will be showing you two ways to put pictures onto a PSP. This is my first instructable so comments and suggestions would be appreciated.
-note: i am using windows vista for this so it may not work on a different computer.
Step 1: Way Number 1
There are a few ways to put pictures on a PSP. The first way is by means of the memory stick duo.
Step 2: Insert the Memory Stick
insert the memory stick into the drive labeled Duo (it may have some other labels too).
Step 3: Opening the PSP's Memory
An autoplay window should have popped up. Click open folder to view files. If the autoplay window didn't show up, click the start button, then click on computer,locate the icon for the drive that has the memory stick in it and open it.
Step 4: Adding the Pictures
Create a folder labeled PICTURE(unless there already is one) and open it.
Now, find the pictures that you want to put on the PSP on you computer and drag them to the window that shows what's in the folder that we just made labeled PICTURE. They should appear in the folder.
CONGRATULATIONS! YOU NOW HAVE PICTURES ON YOU MEMORY STICK!
Step 5: USB Method
Now for the second method to put pictures on you psp.
Plug one end of a USB cord into your psp, and plug the other end into your computer and select USB Connectionon the psp. Now just follow the same instructions in the last two steps.
Step 6: The End
i have shown you two ways to put pictures on a PSP. also check out this must have altoids PSP charger instructable by Jacob S.
