Introduction: Airgun Pellet Mould From Cheap Pliers
materials.
1) pliers
2) 2pcs. dill bits ( 1 smaller than the cal. and the other the same as cal.)
3) vice or vicegrip
4) drill
Step 1:
clamp the pliers with a vice grip
Step 2:
make a punch on the desired location.
Step 3:
drill the pliers using the small drill bit.
Step 4:
make sure that you do not drill through. once in a while open the pliers to see your progress.
Step 5:
again clamp the drilled pliers.
Step 6:
drill the opening with the big drill bit with a depth of 1mm or more.
