Introduction: Arduino Water Level Measurment
This is my arduino project for water level measurement and control the pump when the water level reaches below the minimum level so it open the pump control by a relay and stop the pump when water level reaches to its high point.
i also add liquid crystal 16X2 LCD which show level as bar graph and percentage also show the depth of water from the sensor in CM and the state of pump weather it is on or off and one more thing which is also help that is Ethernet shield which record the the data on a SD card as txt or excel file so that you can analyse your water consumption.
as i am new to arduino adn dont knows to much bout coding i wanna add a push button which can start the pump connected to the relay as mannual when the button push the pump start if it is off or turn off if it is on
there may some grammatic mistake for i am sorry
hardware required
- arduino
- ultrasonic sensor (HC-SR04)
- lcd 16X2 (i used i2c lcd)
- relay (5 V)
- breadboard
- jumper wired
- Ethernet shield (wiznet w5100)
- SD card
for wire connection
sensor
trigger pin connected to ardino pin 3
echo pin connected to ardino pin 2
GND pin connected to ardino pin ground
VCC pin connected to ardino 5V
LCD CONNCETION
SCL pin connected to ardino pin A5
SDA pin connected to ardino pin A4
RELAY
RE1 pin connected to ardino pin 7
HOW IT WORKS
as i set the max level to 30 cm which you can adjust according to your water tank level when the water level goes to 30cm away from the sensor it which display 30 cm, 0 % and empty bar graph.
now when the water level reached to 25cm away from the sensor it will trigger the relay and start the pump which will inrease the water level in the tank and the water level goes high and upto 11 cm the will remain on when it reaches to 10 the water pump will stop.
