Introduction: Baby Go Round
baby go round, Halloween prop
what you will need:
wood, for the base and spinning platform i used some scrap i had it is 3' in diameter
a ceiling fan, they are cheep
3/4" pvc pipe and fittings
paint,screws,jig saw,
Step 1: Mounting the Fan
i took the base and connected the ceiling fan to it with some dry wall screws
Step 2: Cutting Out Spinning Platform
i cut out a 3' round piece of plywood and also cut a 7" hole in the center for the fan
Step 3: The Spinning Platform
set the top plywood over the fan, attach the blade hardware to the fan then mount the plywood to the bottom side of the blade holders
Step 4: The Frame for the Babies
i used a 3/4" pvc 3 way fitting fitting which is basically a 90 with a kick off on one side, build a square and then four corners go down to the platform, if you mark out where they sit and screw 4 pvc caps down to the platform then slide in the frame over the top
Step 5: Paint and Testing
you can paint if you choose, i did a memorizing spiral that looks awesome when spinning,
wire in a cord to the motor and add whatever you want to spin
here is the finished prop https://www.youtube.com/watch?v=aWS-G-15j3o
