Introduction: Building a Rocking Chair With a Crib
In this instructable I will show you the steps to building a rocking chair with a crib for a baby attached to it. This design is fairly simple to construct if you have the right tools and very basic carpentry skills.
Before you start the project there is one thing you should think about. The design I made has a big crib area, this made it hard to find a fitting mattress, you might want to find a mattress first and adjust the sizes in the blueprint accordingly.
Step 1: Tool and Supplies
tool:
hand saw (you can use a table saw for most of the parts)
drill
sander (with soft and rough sanding paper)
brush
staple gun
supplies:
wood glue
super glue
screws (about 30 not longer than the thickness of the wood and 4 slightly longer)
4 metal corner brackets
paint/varnish
fabric (50x50cm for the upholstery 100x100 for the crib)
foam mattress (42x44cm for upholstery and 96x44cm for the crib)
wood:
For this project you need to get whole wood (not MDF, plywood or sandwich boards), I got some pine plates. The 3 big pieces (the sides and the base) are 2.8cm thick, the rest are1.8cm. I recommend you consult with a professional if you decide to use anything different.
The sizes of the plates you will need are specified in the blueprint. In addition you will need a 42X44cm piece of any wood for the upholstery (thick enough so the staples wont go through).
Step 2: Blueprint and Model
I scanned and edited my sketches for this instructable. All the measurements are in centimeters.
As Imsaid before, you might want to adjust some of sizes to better suit your needs.
I also recommend building a scaled model if you have the skill. I used some spare 4mm plywood to build a 1:16 model based on the blueprint. as you can see the scaled model is slightly different from the life size, that's because I made some changes after seeing the model, that's why I recommend you build one.
Step 3: Cutting the Wood
Wings: The two wing are identical so they fit together, all you need to do is draw a 32 cm line at 20cm from each side and connect the ends, then cut through that line. Now cut the bottoms at a 14 degree angle, If you don't have the tools to do this accurately, draw a line 0.5cm from the bottom and cut between that line and the opposite corner as accurately as you can, then correct by sanding. remember that each wing is leaning in a different direction so cut the bottoms accordingly.
Armrest: For the armrest just measure 5cm from each of the bottom corners and draw a line from there to the top corners, then cut.
Sides:The sides are the tricky part. Use a 125cm stick or string, measure 125cm directly above the center of the bottom and anchor the stick/string (I used a long strip of wood and anchored it with a screw to some more wood). Now trace a circle along the edge of your string while it pivots around the anchor point (see picture). The curve on the bottom is part of a circle 2.5m in diameter. use the crossing lines in the blueprint to draw the rest of your mark and cut. Use the extra wood to make armrests and support for the backboard (step 5). Sand down the curves until they rock smoothly on the floor.
Step 4: Assembly
Mark a line under the center horizontal line on side A and B (make the distance between the lines the thickness of your base) and attach two brackets to each side using screws. Find a couple of boxes or any random objects and lay the base flat on top of them at a 20cm height. Flip side B so the curve is facing up and the brackets are towards the base, apply wood glue to the end of the base and attach. use more screws to secure the connection with the brackets.
Once the glue is set do the same thing for side A using something 40cm tall to put the base on top.
After you are certain these 3 main pieces are secure by sitting on them, flip the entire thing on its side (side A flat on the floor) and glue the wings in (I used some tape to hold the wings in place for 24 hours while the glue sets, not very professional but it did the trick, use clamps if you have any).
Now glue the armrest piece on top of the wings (I used weights to make sure its glued evenly on all 3 sides)
Step 5: Backboard and Armrests
Backboard:
cut the backboard piece so that it fits perfectly in the space between the two armrests (you should need to trim off the thickness of the armrest piece). Using leftovers from side A, cut two pieces 7x52.5 cm and round off two corners (see pictures). Glue the backboard to these two piece and leave to dry.
Once dry, flip the entire crib sideways (the place where the backboard goes should be facing up (this is the time to decide if you want the crib on your left or your right as you sit in the chair), glue the backboard into place and hold it down with weights or clamps. When the glue is set, flip the crib back and test the strength of the backboard by leaning against it (you don't want this to fall apart when you have a baby in your arms).
Armrests:
use leftovers from side B to fashion a couple of armrests, I made mine 5x55.5cm with a round edge. I also cut the back corners off making the back only 4cm wide (see pictures). Don't forget to give the back of the armrests a 14 degree angle so they fit with the backboard. Glue the armrests into place (I placed them in the center of the two pieces holding the backboard up).
Addition:
I also use some leftovers from the armrest piece and some scrap wood to make something that will stop the crib from rocking (if you want it to). Just glue two small triangles to a strip of wood at a distance that will allow you to just be able to slide the triangles underneath the curve.
Step 6: Sanding and Paint
Now that the crib is built, sand down all the surfaces and round out all the edges so that there are no sharp edges or splinters anywhere.
If you have an air-compressor and the right fittings for it you can spray paint or varnish using that. Either way, use a brush to even out the paint/varnish and get rid of dripping parts. Always brush with the fiber of the wood not against it.
I used 2 layers of varnish with brown coloring so I could keep the natural wood look and make it darker. If your not sure if the color you picked will come out nicely, paint a leftover piece of wood and wait for it to dry. Use smoothing sand paper (00, the least rough one) between each layer of paint/varnish.
If you plan on keeping this crib outdoors I recommend a layer or two of clear varnish on top of whatever you already used.
Step 7: Mattress and Upholstery
Mattress: If you did not buy a ready made mattress for the crib, you have some sewing work ahead of you. Buy a waterproof fabric (about 100x100cm) and make a case for the foam mattress. I recommend also making a removable sheet that you can take off and wash so the baby wont be directly on the waterproof material which is usually not comfortable.
I don't have any pictures of making the cribs mattress because I bought a ready made mattress that was twice the width and just cut out half the foam from inside.
Seat: Cut a piece of wood 42x44cm (at least 0.6 cm thick), round out the edges, glue the foam mattress to the wood with super glue (or any strong glue), cut the edge of the foam at about a 45 degree angle to give it a slope at the ends. Using a staple gun, tightly staple the fabric of your choosing (I chose black fake leather) from all sides to the bottom of the wood then cut off any extra fabric. Center the entire thing on the seat and secure it into place using slightly long screw from the bottom (make sure your screws are long enough to get through the base but not through the wood you used for the upholstery)
Second Prize in the
Instructables Design Competition
UP! Contest
33 Comments
1 year ago
All sizes converted from metric to imperial. CM to Inches for us Westerners.
1 year ago
How much wood did you start with size wise in inches if you can.
5 years ago
I'm getting ready to make your crib for my first grandson. The blueprints do not show up well on the instructables page. Could you send a copy of the blueprints for me please? Filicajun@yahoo.com
6 years ago
Hi, Do you think that the legs would be strong enough if you would cut out the middle like in the original images? I wonder about the transversal forces?
Reply 6 years ago
I guess it depends on the type and thickness of the wood you're using. If you want the cut-out you should make the bottom part of the legs from a straight plank of wood bent to an arc, this way the grains of the wood are going along the leg and help support it. I'm not an engineer but I believe that will work
6 years ago
I would love to have this made for my daughter and new grandchild due in December
6 years ago
Is there anywhere I can buy one
Reply 6 years ago
None that I know of. sorry
7 years ago
This is awesome... Would you by any chance have the files for it? I suck at drawing, but would love to go to my local makerspace and get the pieces cut out.
Would really appreciate it, if you could send them to me at mail(a)boegh.nu
Reply 7 years ago
This project was done before i had any knowledge of any computer program designed for these kinds of things. the blueprint in the instructable is a Photoshop trace of a hand made sketch I made and is proportionate.
I believe any wood supplier will cut most of the pieces for you if you show them the blueprint (they might charge a little extra to do the curves)
7 years ago
I love this and would like to make one. I'm just curious, are there no supports for the backrest? it is only glued, correct?
7 years ago on Step 4
Nice design, simple and elegant. Out of curiosity, I see that you used metal brackets to attach the base. Did you consider using a hardwood peg, or did you decide that they would not support well enough? Like I said, merely curious.
Reply 7 years ago on Step 4
Thanks for compliments (:
I hadn't considered using wooden pegs. I figured metal brackets are stronger, simpler and you don't see them anyway (because they are underneath) but I guess you can do it your way too.
You should consider it doesn't only hold the sides and base together it also helps keep the whole thing from leaning sideways
Good points. It's all about the experimentation. :) Be well, and best of luck with your future projects.
7 years ago on Introduction
Great design, love it.
8 years ago on Introduction
looks good just wish it all was in standard measurements
10 years ago on Introduction
Deserves more attention. Excellent design....clean and functional.
Looks great.
Would be perfect for my expecting cousin, but, I was wondering what the weight limit would be and if adding a third 'wing' to it, between the crib and the seat, could or would make it any stronger and the best way to go about doing that.
Never mind, I spent the day thinking about it and figured out how I can modify this with a third 'wing' and a few changes for the mattress and seat sizes :)
That is the coolest piece of furniture I have evr seen in that catagory
