Introduction: Bushmaster M17s
hey guys !
this is my bushmaster m17s replica thats like 95% perfect as a replica, and also works really well too.
stats:
up to 60 feet with 3 #28 bands
not very accurate
packs a strong punch
looks awesome
spring loaded curved mag
mag release system
safety 100% reliable
uses a lot of broken parts (though a few can be taken off, if you don't build all the mechanisms)
uses at least 11 hinges, but none are necessary (all are for looks, to resemble the real gun which i replicated)
extremely comfortable and easy to use
short ram pull
hope you guys'll like this as much as i do (and i DO)...
here's a vid of it in action:
stats:
not very accurate
looks awesome
mag release system
short ram pull
my gun
Step 1: Fore Grip Area
a simple step to get you warmed up...
Step 2: "scope"
another simple step.
Step 3: Handle/trigger Area
here it's starting to get tricky...
Step 4: Barrel
this part is generally a simple pattern with slight differences here and there. notice the differences... they are important.
Step 5: Stock
this is by far the hardest step, thats why it's saved for last. it contains pretty much all of the guns mechanisms (only one not there is the trigger itself). get this step over with and your done building the parts of the gun.
Step 6: Assembly and Band Placement
a simple step to end it all up with. to fire (explanation for the newbies), pull back the ram (blue rod in the gap at the back of the stock) until you here 3 clicks (1 - bullet, 2+3 - trigger). then, be careful when you shoot not to rest your face on the ram, and pull the trigger.
Step 7: Magazine
this is the curved magazine that holds 8 bullet (can be made bigger of course). if you want to make the regular magazine that is the same approximate size and can hold 10 bullets, just build it from the pics in the intro, and from the vid on my SABR v2 note on the v1 'ible.
to learn how to insert the spring (bendy) and the mag pusher, watch this video:
