Introduction: Camera Mount Hands Free
ok you need a piece of copper wire im using thick stuff for stability. im working on a thiner copper line /lines but thats another instructable also you need two plyers and a bolt that will screw in to your camera and two nuts for said bolt
Step 1: Now Cut Off the Bolt Head
you might need a solid surface and pinch bolt with snipps and hammer the nippers ever so gently or you could just leave the head on the bolt if its big enough to secure the copper line between the nut and head i had already cut the head off my bolt on another instructable and iprovised by using another nut
Step 2: Now Screw a Nut Onto the Bolt
i hammer the end of the bolt and scare the threads and thread a nut to the bottom until it screws no more thats what you want for the nut to stop
Step 3: Now Bend a Loop in the Copper
i start the loop on the copper line but before i bend it all the way i place the bolt in the loop the grimp it like a mad man you wanna use a hammer
Step 4: Now Screw on Another Nut
screw on another nut and smash the copper line / loop between the to nuts very tightly and secure
Step 5: Now Screw Your Camera on to the Bolt
you can bend the copper anyway to make a stand or wrap around a tree / post or to secure it to a table or just stick it in the ground
