Introduction: Can Tab Chain Body Armour
grade 2 aluminum can tab armour.
Strong and easy to make, but takes a while to make.
Step 1: Materials
for this you will need
- a lot of copper wiring
- needle nose pliers
- wire cutters (unless the pliers come with wire cutters)
- and a couple hundred can tabs
Step 2: Stringing the Tab Chains Together
cut a little wire and have two tabs ready. Make a u with the wire and slide it into one end of one tab. Make sure that you do both holes, and that it is the same kind of hole.
Step 3: Bonus
i took apart a vacuum cleaner to get the copper wiring and theese metal squares you can see in the finished product. Mine is a plate chain hybrid. But other things you can do are make capes, gloves, whatever. (I'm still working on the gloves.)
