CollectionCar Maintenance and ModsBy Mjtrinihobby in WorkshopCars3,25927Routine Car Maintenance plus important modifications.Routine Car Maintenance plus important modifications.Tightening a Loose Side Mirror. by Mjtrinihobby in CarsQuick Clean for an Engine Air Filter. by Mjtrinihobby in CarsFixing a Slack Gas Pedal. by Mjtrinihobby in CarsCleaning License Plate Lamps. by Mjtrinihobby in CarsTroubleshooting a Nonfunctional Windshield Wiper. by Mjtrinihobby in CarsInjecting Pag Oil Into a Car's Air Conditioning System. by Mjtrinihobby in CarsBreather Line for Hyundai Trajet 2000 Valve Cover. by Mjtrinihobby in CarsCreating a Breather Line for Honda Civic 1999 Valve Cover. by Mjtrinihobby in CarsTop Up of R134a Refrigerant. by Mjtrinihobby in CarsRecharging My Car's Lithium Battery. by Mjtrinihobby in CarsRegreasing a Rear Wheel Bearing - Honda Civic 1999. by Mjtrinihobby in CarsFixing a Car Battery Pole Clamp. by Mjtrinihobby in CarsFixing an Annoying Noise From My Car's Wheel. by Mjtrinihobby in CarsVacuum Bleeding Brake Lines - the One Man Job. (Hyundai Trajet 2000) by Mjtrinihobby in CarsReplacing an Engine Starter! (Hyundai Trajet 2000) - 300th Instructable! by Mjtrinihobby in CarsVacuum Extraction of Transmission Oil! - Hyundai Trajet 2000. by Mjtrinihobby in CarsChanging Engine Oil and Filter! - Honda Civic 1999 D15B Engine. by Mjtrinihobby in CarsInstalling an Oil Air Separator! by Mjtrinihobby in CarsUpgrading an Oil Air Separator! by Mjtrinihobby in CarsVacuum Bleeding the Brake Lines - Honda Civic 1999. by Mjtrinihobby in CarsQuick Check/Topping Up a Car's Air Conditioning. by Mjtrinihobby in CarsCleaning a Car Battery Pole. by Mjtrinihobby in CarsVacuum Extraction of Transmission Oil. by Mjtrinihobby in CarsFront Wheel Suspension Inspection. by Mjtrinihobby in CarsOuter Tie Rods Inspection.by Mjtrinihobby in CarsFront Brakes Inspection. by Mjtrinihobby in CarsReplacing Rubber Hose Caps in My Car. by Mjtrinihobby in CarsOuter Cv Joint Inspection. by Mjtrinihobby in CarsWhy Silicone Hoses Cannot Be Used for Oil and Fuel. by Mjtrinihobby in CarsReplacing Transmission Speed Sensors (Hyundai Trajet 2000). by Mjtrinihobby in CarsCar Remote Starter Installation! by Mjtrinihobby in CarsInstalling Talking Reverse Sensors! by Mjtrinihobby in CarsReplacing a PCV Valve for Hyundai Trajet 2000! by Mjtrinihobby in CarsUpgrading Vacuum Hoses for Hyundai Trajet 2000. by Mjtrinihobby in CarsReplacing Spark Plug Tube Seals for Hyundai Trajet 2000.by Mjtrinihobby in CarsReplacing the Valve Cover Gasket for Hyundai Trajet 2000.by Mjtrinihobby in CarsReplacing Coil Packs and Spark Plug Wires for Hyundai Trajet 2000.by Mjtrinihobby in CarsInstalling Silicone Radiator Hoses! by Mjtrinihobby in CarsReplacing a Radiator Fan Motor! by Mjtrinihobby in CarsReplacing Engine Vacuum Hoses! by Mjtrinihobby in CarsReplacing Radiator Mounts. by Mjtrinihobby in CarsLow Cost Way to Replace a Car Trim. by Mjtrinihobby in CarsReplacing a Starter Solenoid (Honda Civic 1999, D15B Engine). by Mjtrinihobby in CarsReplacing a Pgmfi Relay (Honda Civic 1999). by Mjtrinihobby in CarsReplacing a Map Sensor (Hyundai Trajet/sonata) by Mjtrinihobby in CarsAdding a Dash Camera to My Drive Record Unit. by Mjtrinihobby in ElectronicsReplacing a Front Bumper (Honda Civic 1999)! by Mjtrinihobby in CarsA Drive Record Unit (DRU) for My Car!by Mjtrinihobby in ElectronicsReplacing the Lower Radiator Hose on a Hyundai Trajet/sonata. by Mjtrinihobby in CarsReplacing the Timing Belt and Crankshaft Seal (Honda Civic 1999, D15B Engine). by Mjtrinihobby in CarsRefreshing the Seal on a Schrader Valve. by Mjtrinihobby in CarsReplacing a Car Door Jamb Switch. by Mjtrinihobby in CarsFixing a Vibrating and Noisy Car AC Compressor. by Mjtrinihobby in CarsReplacing a Camshaft Seal (Honda Civic 1999, D15B). by Mjtrinihobby in CarsFinding and Fixing an Engine Oil Leak. by Mjtrinihobby in CarsReplacing a Fuel Pump (Honda Civic 1999)! by Mjtrinihobby in CarsReplacing Transmission Speed Sensors (Hyundai Trajet/sonata) by Mjtrinihobby in CarsA New Way to Lube My Idle Air Control Valve (Honda Civic 1999, D15B Engine). by Mjtrinihobby in CarsRemoving an Alternator Pulley! by Mjtrinihobby in CarsInterfacing Car Sensors to My Car Assistant.by Mjtrinihobby in ElectronicsReplacing an Engine Mount (Hyundai Trajet) by Mjtrinihobby in CarsMy Car Assistant (Embebbed Car Automation Computer)!by Mjtrinihobby in ElectronicsReplacing Engine Mounts in a Hyundai Trajet/Sonataby Mjtrinihobby in CarsReplacing an Engine Mount.by Mjtrinihobby in CarsMaking the Viper Smartstart Phone App Even Cooler! by Mjtrinihobby in SoftwareRemoving Extra Electrolyte From a Car Battery. by Mjtrinihobby in CarsReplacing an Upper Radiator Hose (Hyundai Trajet)by Mjtrinihobby in CarsReplacing the Timing Belt (Honda Civic 1999, D15B Engine) by Mjtrinihobby in CarsServicing a Positive Crankcase Ventilation (pcv) Valve. by Mjtrinihobby in CarsPatching a Leaky Coil Packby Mjtrinihobby in CarsFixing a Car Alarm Remote Antenna. by Mjtrinihobby in ElectronicsCar Maintenance at Home!by Mjtrinihobby in CarsFixing a Broken Engine Electrical Connector. by Mjtrinihobby in CarsReplacing the Positive Crankcase Ventilation (pcv) Valve. by Mjtrinihobby in CarsReplacing Outer Tie Rods. by Mjtrinihobby in CarsReplacing Upper Control Arms (Honda Civic 1999 D15B). by Mjtrinihobby in CarsQuick Under Engine Inspection. by Mjtrinihobby in CarsChilling a Gasoline Return Line. by Mjtrinihobby in CarsReplacing Fuel Injectors (Hyundai Trajet) by Mjtrinihobby in CarsBleeding Brake Lines - Quick, Effective and Messy. by Mjtrinihobby in CarsReplacing the Engine Water Pump and Tensioner Pulley (Honda Civic D15B).by Mjtrinihobby in CarsServicing a Starter Motor (Honda Civic 1999, D15B Automatic). by Mjtrinihobby in CarsReplacing an Aged Oxygen Sensor (Hyundai Trajet). by Mjtrinihobby in CarsSuper Easy Way to Remove and Reinstall the Crankshaft Pulley Bolt (Honda Civic 1999 D15B) by Mjtrinihobby in CarsQuick Fix for a Broken Windshield. by Mjtrinihobby in CarsReplacing the Distributor Without Using a Timing Light (Honda Civic 1999 D15B)by Mjtrinihobby in CarsReplacing a Fuel Return Line. by Mjtrinihobby in CarsHow I Hypermiled My Car.by Mjtrinihobby in CarsReplacing Transmission Fluid. by Mjtrinihobby in CarsReplacing Fuel Injectors (Honda Civic 1999 D15B)by Mjtrinihobby in CarsAdjusting the Engine Valve Clearance (on My Honda Civic 1999 D15B)by Mjtrinihobby in CarsHelping Out My Car Air Conditioning Again! by Mjtrinihobby in CarsHelping Out My Car Air Conditioning Part 3!by Mjtrinihobby in CarsReplacing the Engine Mounts on My Honda Civic 1999. by Mjtrinihobby in CarsReplacing My Car Deck With a Lepai Amplifier. by Mjtrinihobby in ElectronicsMaking a Replacement Dashboard AC Vent.by Mjtrinihobby in CarsWiring My Car Air Conditioner for MAXIMUM Cooling!by Mjtrinihobby in CarsThe Most Effective Way to Increase Bluetooth Range!by Mjtrinihobby in ElectronicsStart/Stop, Lock/Unlock My Car From My Phone! DECOMMISSIONED by Mjtrinihobby in ElectronicsTesting a Viper Bluetooth Smart Start Moduleby Mjtrinihobby in ElectronicsRetrofitting My Car AC Blower With Pwm Speed Control! by Mjtrinihobby in ElectronicsImproved Cooling of Cree Led H4 Headlight - DECOMMISSIONED.by Mjtrinihobby in ElectronicsRepair of Dislocated Front Turn Signal Lampby Mjtrinihobby in CarsLiFePO4 Battery for Gasoline Engine Starting. by Mjtrinihobby in ElectronicsServicing the Wiper Motor on a Honda Civic 99by Mjtrinihobby in CarsReplacing the Rear Shock Absorbers on a Honda Civic 1999. by Mjtrinihobby in CarsReplacing Rear Wheel Hubs on the Honda Civic 1999. by Mjtrinihobby in CarsBleeding Air From a Brake Line. by Mjtrinihobby in CarsReplacing of the Map Sensor on My Honda Civic 1999 D15B. by Mjtrinihobby in CarsTopping Up a Car's R134a Air Conditioning System. by Mjtrinihobby in CarsCleaning a Car's Headlamps. by Mjtrinihobby in CarsReplacing H7 Oem Headlamps With Led! by Mjtrinihobby in LEDsReplacing the Throttle Position Sensor on the Honda Civic 1999 D15B Engine. by Mjtrinihobby in CarsReplacing Spark Plugs! by Mjtrinihobby in CarsReplacing a Fuel Filter (Honda Civic 1999 D15B). by Mjtrinihobby in CarsReplacing Rear Suspension Upper Control Arms (Honda Civic 1999 EK3). by Mjtrinihobby in CarsChanging Front Shock Absorbers (Honda Civic 1999 EK3)! by Mjtrinihobby in CarsReplacing Spark Plug Wires (Honda Civic 1999 D16Y7)! by Mjtrinihobby in CarsReplacing a Fuel Pressure Regulator (Honda Civic 1999 D16Y7)! by Mjtrinihobby in CarsInstalling Aftermarket Rear Suspension Lower Control Arms! by Mjtrinihobby in CarsReplacing an Idle Air Control Valve (Honda Civic 1999 D16Y7). by Mjtrinihobby in CarsReplacing an Engine Coolant Temperature (ECT) Sensor (Honda Civic 1999 D15B). by Mjtrinihobby in CarsEngine Crankcase Breather Filter (Honda Civic 1999 D16Y7). by Mjtrinihobby in CarsCleaning the Grime From My Engine. by Mjtrinihobby in CarsReplacing a Car's Hvac Blower Fan. by Mjtrinihobby in CarsReplacing a Car's Heated Oxygen Sensor! by Mjtrinihobby in CarsExhaust Manifold Replacement (Honda Civic 1999 D15B Engine and EK3 Chassis)! by Mjtrinihobby in CarsPreserving a Spare Alternator. by Mjtrinihobby in CarsDouble Team for an Engine Air Filter! by Mjtrinihobby in CarsLubing an Idle Air Control Valve. by Mjtrinihobby in CarsReplacing Trailing Arm Bushings on My Honda Civic! by Mjtrinihobby in CarsReplacing the Valve Cover Gasket on My Honda Civic 1999 D15B Engine. by Mjtrinihobby in CarsReplacing Exhaust Rubber Hangers. by Mjtrinihobby in CarsFixing the Rear Door Lock Actuator on My Honda Civicby Mjtrinihobby in CarsReplacing the Power Steering Pump in My Honda Civic 1999by Mjtrinihobby in CarsPreserving a Power Steering Pump. by Mjtrinihobby in CarsReplacing AC Idler Pulley on My Honda Civic 1999by Mjtrinihobby in Cars
