Introduction: Cardboard CD Case
in this instructable i will be showing you how to recycle a cracker box into a usefull cd case
please rate, comment or subscribe!!
Step 1: Materials
here is what you need:
1: workspace
2: utility knife
3: plastic CD case
4: CD
5: cardboard ( like from a cracker box cereal box or possibly poster board)
6: Brass Fasteners ( Brads)
___NOT IN PHOTO___
7: tape ( duct tape, clear tape, masking tape, any will work)
6: pen/pencil ( optional)
Step 2: Part One
open your cardboard box so it can lay flat, you utility knife will help you here.
*does not apply to posterboard
Step 3: Next Step
open your plastic cd case and place it onto the unfolded cardboard box
*note if prefered, trace the cd case but this is not needed*
Step 4: Cutting
grab your utility knife and cut around the cd case, or if you have traced cut along the traced line.
Step 5: Result of Cutting....
after cutting you should have a piece of cardboard about the size of an open cd case, it will be a little bit larger ( than open cd case) but dont worry it will have a purpose.
recycle the extra cardboard
Step 6: Next Step
in this step you will perferate two lines along the center of the cardboard ( similar to the hinges of the plastic cd case ( if cut right the side of the case ( the black part) can be used as a guide)))
this step may be a little confusing
Step 7: Almost Done
puncture a hole in the center of the cardboard case ( a brass thingy will go in here) make sure you make another directly across from it.
Step 8: Brass Thingy
take one brass thing and place it into the hole you just cut
Step 9: Falling Prevention
stick some tape on the end
Step 10: Using the Case
place your cd onto the end of the brass thingy
Step 11: Closing
to close the case fold the cover over and make sure the end of the brass thing goes into the hole. when closed fan out the brass thing so it wont open
Step 12: And There You Have It
congradulations you have made a paper cd case! it can be drawn on and labled pretty nicely.
