Introduction: Cardboard Chair
cardboard chair, it´s resistence, cheap and lighweight.
The design comes from a right triangle (each side of the triangle has the same measure), that form pyramids.
The size of de chair, depends on the size of each triangle, will be the size of your cardboard seat. In my project used 24"x24"x24" triangle.
You will need 6 Triangles to get the wholer body of the chair, and you will need 2 triangles to do the seat of the chair.
Step 1: Cut
materials: cardboard* (double sheet), glue, glue gun, gummed packing tape (thick 3").
instruments: scissors, cutter, meter, pencil
First step:
Cut 8 right triangles(6 for the whole body and 2 for the top) I recommend you, 24X24X24 inches
Take 6 rectangles and then cut righ in the half and you will get.
6= 12x12x12" right triangles and 6 trapezoids
*In this project you can use recycled or reused old cardboard.
First step:
Step 2: Paste
Now you have al de pieces
And 2 right rectangles of 24X24X24"
It´s time to paste
You have to do two pyramids with the 6 rectangles
and 2 semi pyramids with the 6 trapezoids
You have to use the gun glue, go faster before the glue gets dried
It´s time to paste
Step 3: Seat
With the 2 triangles left, cut in the center another triangle, to do the seat. look the images. Use the glue to paste all the layers of the seat.
Look!! that you have to cut a section in every corner of the triangle, that will join with the bottom part
Step 4: Assembly
Now you have all the parts, you justo have to assambly and use the gummed packing tape (thick 3"). to secure the whole chair
Put the two triangles in the half pyramid
Be sure to put to all the borders the gummed packing tape.
One half pyramid has to be cut in the corners to put the corners of the top of the seat
Step 5: Get Ready to Use
Enjoy your chair and good luck!!
