Introduction: Cat Tree Endless Entertainment for Your Furry Friends
In this inscrutable you will learn to make an cat tree that will forever keep your cats occupied
I would like you to rate comment and give constructive criticism.
Step 1: Supplies
supplies:
cats Duh
1 large wire spools
1meadum spool
2 small spools
screws
sharpie
brain, feet etc.
tools:
jig saw
carpenters square
whole saw
drill with Philips screw driver bit
cats Duh
1 large wire spools
1meadum spool
2 small spools
screws
sharpie
brain, feet etc.
tools:
jig saw
carpenters square
whole saw
Step 2: Make Your Mark
if you don't want it to be in a corner don't do this if you do use your carpenters square to make a 90 degree angel then transfer it to all the spools then cut all your marks.
Step 3: Wrap It Up
locate the bolts on top of your big spool then use your whole saw bit to drill wholes on the bottom of medium sized spool corresponding with the bolts on the top of the big spool.
Step 4: Finshed
Now screw it all together make sure the wholes are aligned with your bolts and your done now your cats will be forever thankful.
