Introduction: Cheap and Easy Halloween Eye Buttons
About: Being home schooled my entire life, I consider myself a bit of an autodidact. As a youngin' my favorite things were taking tings apart, building with LEGO and watching TV. When I was an early teen I stumbled …
im going to show you how make cheap and easy eyeball buttons for halloweenm, you will need.
a small paintbrush.
white acrylic paint.
green, blue, or brown actylic paint.
regular old clay.
a small marker (the same color as the paint you chose but darker.)
an old colored pencil.
and a small screwdriver
Step 1: The Clay.
take a small wad of clay, roll it into a clyinder, make sure its 4 inches long. the cut it in half and roll the 2 halves into balls, press them against something hard to make them into domes. then using your pencil, press into the center of the clay until your almost through, the using your screwdriver make 2 small holes in the bottem of the big hole. (sorry I didnt get any pics of that part. I thought i did. but i didnt)
Step 2: The Paint
now but the pencil in the big hole and the paint the domes white. now mix your color paint (I used green) and mix it with a little
bit of white paint to make it light. now press you brush against the pencil and then slowly turn the pencil to make a nice green circle. now its starting to look like an eye!
Step 3: The Marker.
once the paint and clay ar dry. take your marker and make lines around the borders of the light green. then using the tip of the marker. make fine little lines point into the light green.
congradulations! your done.
dont worry if your eyes look like crap from close up. the farther away you are the better thay look.
now you can sew the onto anything that you think needs eyes.
