Introduction: Cheap and Quick Warming and Sore Muscle Relief
Its cold outside, even here in florida its dropping below freezing. Hands and feet are especially difficult to get/keep warm, here's a trick my granddad taught me many years ago and its as close as the condiment shelf of your refrigerator. It also works great on sore muscles and for those suffering from arthritus
WARNING: Use caution when using this method and be sure not to touch your eyes ! As with any home made remedys caution should be used in the preperation and use until you see how your body reacts
Step 1: You Will Need
I usually keep a bottle of red water available, most of you will know this as tabasco, louisiana,franks, hot sauce but Im out so Im using a habanero hot sauce. You can use the red water straight from the bottle but using some sort of oil will make it easier to massage in and helps with skin dried from the cold. Your going to need.....
a bottle of Hot Sauce, tabassco or any thats in your fridge
Oil, olive oil works best but any cooking oil will do
a shot glass
Step 2: Mix It Up
fill the shot glass about half way with the oil, add anywhere from a couple drops to a couple teaspoons of the hot sauce you chose.. WARNING: the more hot sauce you use the hotter it will be on your skin so start out small. Now stir the 2 ingredients together
Step 3: Rub It in , Rub It In
all thats left is to use it, take a couple drops and rub onto your hands and feet or any sore muscles. (edit) To reverse the effect (if the heat is to much) wash the area with rubbing alcohol (or a --drinkable--alcohol) and soap and water
This will NOT replace heat packs or extreme weather clothing but works great when you get inside and just cant get your feet warm, again be VERY CAREFUL after using not to touch your eyes and use caution when going to the bathroom
(edit) as I mention in one of the comment replys below, there's an over the counter arthritis creme that contains cayenne pepper extract. I always thought granddad was special but now I realize he was 40 + yrs ahead of modern medicine ! !!! ! !
(edit2)
The amount of smell will depend on the type of oil used and the amount/type of hot sauce used but it shouldn't be any more than over the counter cremes like bengay(tm) give off.
39 Comments
12 years ago on Introduction
this is effective for arthritis because the capsaician in cayenne and peppers interferes with the pain receptors, taken interally via capsules it first increases the pain and then cuts it altogether, externally as a rub it just cuts out the pain, you can buy creams with capsaician in them for this, been around a long time.
Reply 11 years ago on Introduction
Make sure you are not a parent with a baby. Handling the baby with this mixture on your skin might burn the baby's skin...
thats a good point... thank you for mentioning it
I was at work (at a hospital) when I read this and thought I'd give it a try. We didn't have any oil, but we did have the red water in copious amounts. We also had plenty of lotion (due to the need to constantly wash our hands). So I figured what the heck. It looked like something you would dip chicken fingers in, but it calmed down my arthritis like nothing I've ever tried before. Also the lotion scent overpowered the smell of the Louisiana hot sauce. Thanks. Great idea!
Reply 12 years ago on Introduction
I'm glad it helped and the lotion sounds like a great alternative.. thank you for letting me know
12 years ago on Step 2
hey l8nite...
I tried your recipe, and let me tell you that maybe I did a mistake, so help me with this...I used Tabasco sauce and canola oil, the quaentities that you said, and doesn`t work at all....it never came hot... so, what should I change?? do you have another real recipe?? or it has a secret?
thanks!!
When I have any of the red water "hot" sauces like tabasco or franks or luisianna, I usually use it straight from the bottle or with just a couple drops of oil to help make it easier to rub in. Try using your sauce of choice straight and see what effect it has and adjust from there. The instructable shows me using just a couple of drops of Habanaro hot sauce because its more potent than cayenne type sauces, you can also try using dried cayenne pepper mixed in oil. I find it very helpful in relieving minor arthritus flare ups and achey muscles as well as giving a warm feeling to cold limbs but of course it doesnt work as well as real heat (fire) or heating blankets. Hope this helps
For a opposite effect buy some mentholatum ointment it warms at first but it gives you a chilling sensation afterwards great to save on air conditioner...
13 years ago on Introduction
Nice tip. A bit of commonsense, with a warm feet result.
Given that we are expecting 39c tomorrow/next day, and we went to 41c last week, this is on hold!!!
I am looking for something that will do the opposite! (From the land downunder!).
lol, i'm from aussie too! i remember ads for "ice body splash" in the 80's. i think it was just scented rubbing alcohol. made you feel cold though.
Hi! Yes, I used to get some cologne called Ice, by the 4711 people. It gave an instant cooling effect.
Needless to say you can't get it now.
Reply 13 years ago on Introduction
A typical american barbarian I don't know how to convert celsius to farenheit, but I take it that 41c is rather warm, last week we had temps in the upper 70's to low 80's f, today the high is 48f with an expected low of 27f ! Its predicted to be a record cold spell for florida = (
Really informative Instructable. Thanks! I am Canadian, and therefore should use and understand the metric system, but alas, when I was young, we still used the Imperial system. Here's what I know, (and then I guess from there lol.) Water boils at 100 degrees C and freezes at 0 degrees C.
I know I know, I am a brainiack ;0)
BTW, I lived in MI for 5 years and was treated very well and very kindly and never once did I run into any Barbarians. Sorry but YOU seem kind too so the Barbarian award can not be claimed by you ;0)
Don't put yourself down kiddo,- I don't know how to convert the other way!!
I know 41 c is about 102/3 f......I guess Google is our friend if we really want to know!
(Up in the North West mining areas, the summer temperatures can get to 48/9 c!! And in Coober Pedy -the Opal mining area, people live underground where the ambient temperature stays around 24 c. Even their Motel is completely underground!).
For the Northern and Southern Hemispherians....what we DO know, is when it is too darned hot-and too darned cold!
In Britain I suffered badly with chilblains on my hands and feet - any way of alleviating that would have been handy.
It's morning here - I will head out before the excessive heat,- then come back and hunker down with the cooler on.
Good luck to all of you coping with such freezing temperatures (anonymouse 197 - I saw on our news this am. that the Northern area of Britain has had heavy snow). I envy you;- you envy me...
Such is life!!
You don't know how much I envy you. 0c in cumbria and its snowing/sleeting. :(
Well, the grass on the other side of the hill is always greener!, because I envy you!!
Cumbria is beautiful! Snow and sleet...honestly, I'd give my eye teeth!!
I've been here 32 years (from Shropshire),......and it IS getting MUCH hotter. Our heat wave last year, and this year reached temps of 46c;-people were dropping like ninepins-it killed 72.
Without air-conditioning you are in a really dangerous situation.
We are also in a drought. This country will turn to desert in a heartbeat if water runs too low,-it literally will become uninhabitable.
I have to admit the young "Poms" backpackers are on the beach in seventh heaven--because it's a novelty.
How I long for a winter Christmas. We sing Santa/snow songs in sweltering heat!!
Oz has been good to me, but as you can guess, in the summer, I find it increasingly unlivable.
Rant over!
(My apologies for highjacking your Instructable 18nite {o_-} !).
don't put this on sensitive areas. an ex boyfriend once mixed up his "personal" in the shower massage oil with his foot warming oil. lets just say taking him to emergency with 2nd degree chemical burns on his privates was interesting.
My father-in-law used to work in the woods. He would put several sprinkle of cayenne pepper in his socks each day. He swore that it kept his feet warmer.
I made some of this up yesterday and it worked awesome! I used olive oil and "Texas Pete" my favorite table sauce.
I tried the same thing I do with Armorall and it worked great.
I soaked a soft car waxing sponge-thingy in it and used it to massage my sore arm muscle. When I was done I soaked it some more and placed it in a zip lock bag. Now I can just grab the thingy out of the bag and it is ready to go. (I do squeeze it out a little into the bag before removing it) I think today I will try warming the thingy in the microwave for a short burst and see how that works.
Thanks for sharing this great idea - very practical!
www.theruralindependent.com
That's a really interesting adaptation, I'll have to keep it in mind. Thank you for the comment
