Introduction: Cheap Solar Car for a Kid
About: i dont know (=
ok so the first thing you need to do is get all the things you need a small plank of balsa wood, a 2 volt motor, 2 small hollow rods that you can cut, a bunch of wires, some wire clips, a non hollow rod that a small gear can go around all so a small gear and a nether one that the can go on the motor, some thing to prop up the panels on the car and 2 solar panels and tape and some thing to make in to wheels legos are good for this
Step 1:
next take you wood and attach the two hollow rods to the plank
Step 2:
then you put in the rods then put on the  wheels but befor you put on the for the back.
Step 3:
fist you should soter on some wires to the solar panels
Step 4:
then you put on to a the rod a gear then put on the wheels.
Step 5:
next hot gun the motor to the to he wood and put a gear on the motor have the gear go straitly on to the other gear
Step 6:
 take the solar panels and prop them up with what ever  make it so the sun will be on it for as long as it can
Step 7:
then put the wires in there clips like this (+ +)  (- -) the atake those to the motors prongs
then let it fly so to speak
